jaymatt1978
1st Responder Correspondent
Getting a brief hit on 462.9750 PL 146.2 down here in Cape May when I lived in Bergen County this was Jersey City Medical Center dispatch.Do they still use it???
It wasn't JCMC. As stated they are now on the NJTCS. I worked on JCFD from 1992 and JCMC was on an 800 commercial repeater until 9-11-01 when that system went down with the towers and then went back to the VHF 155-235 channel they were originally on until they switched to the state system.ok so this was ducting. Thanks
Just for the sake of historic accuracy, the MC went from 155.235 to a Motorola-owned SmartNet 900 MHz system. They were never on 800.It wasn't JCMC. As stated they are now on the NJTCS. I worked on JCFD from 1992 and JCMC was on an 800 commercial repeater until 9-11-01 when that system went down with the towers and then went back to the VHF 155-235 channel they were originally on until they switched to the state system.
Thanks for this. I remember being a young kid growing up in Bayonne in the late 80's listening to the MC. "MC14 for the assignment in Bayonne." All the other kids in my neighborhood were playing Atari and I was glued to my scanner listening to Bayonne and JC for hours on end.Just for the sake of historic accuracy, the MC went from 155.235 to a Motorola-owned SmartNet 900 MHz system. They were never on 800.
The JEMS plan did not authorize dispatch on UHF, even though the 1986 implementation of HUDCEN included a "Mixer" feature on MED 9 and 10, similar to FDNY and NYCEMS. As "MC-11," the communications coordinator and designer of the 1986 iteration of the HUDCEN facility, I had intended to move dispatching operations to one or the other. BRAVO (Bay Ridge Volunteer Ambulance Organization) in Brooklyn used one of the two frequencies for their dispatch and coordination. At the time, NJ OEMS did not want any activity coopting MED 9 or 10 to a single agency dispatch. MED 10 had originally been investigated as an annunciator display channel for open MED channels at the various MICU dispatch facilities. It didn't work because all of the base stations at each of the communications centers were not simplex, but semi-duplex.
Originally the MC operated on 155.265 but was heavily interfered with by Hatzolah before they switched to 160 MHz. The MC changed from 265 to 235 around 1984. In 1986, a voting comparator and additional channels (JEMS 2, 3, and SPEN/JEMS 4) were added to establish a Hudson County EMS control point with DTMF decode, per the JEMS plan. This was replaced circa 1991 by the leasted talkgroups. JCMC did not own the trunked system, similar to McCabe's 800 dispatch in the mid-80s being a community repeater on the WTC. McCabe's also switched to the 900 MHz SMRs.
The 900 system was divided between the World Trade Center and Claridge House in Verona and required a scanning radio. Jersey City and Hudson County were in such position that the WTC overshot much of the region and did not cover the west side. Claridge House had to cover that area.
The VHF simplex system was reactivated immediately after 9/11. In subsequent years until their move to NJICS, they repeaterized 155.235 and moved the repeater off the Surgical Building (the middle building in the original Medical Center complex) to the Hudson County administration building. A second repeater frequency was added.
NJICS addressed a longstanding spectrum shortage in Northeastern NJ. When I was a paramedic at the MC (circa 1985 - 1987), private ambulance services in Staten Island, licensed at power levels much higher than the MC, would frequently obliterate communication. Building out the voting receivers helped, but did not entirely solve the problem. In 1986, we solved some of the problem by brute force, buying 110 Watt Syntor X9000 mobile radios.
Thank you for remembering.Thanks for this. I remember being a young kid growing up in Bayonne in the late 80's listening to the MC. "MC14 for the assignment in Bayonne." All the other kids in my neighborhood were playing Atari and I was glued to my scanner listening to Bayonne and JC for hours on end.
I reached out to a friend who follows NYC's volunteers. I'm told they're using radio emulation over LTE, but still have the MED-9 capability.Out of curiosity is BRAVO still around and what type of communication scheme are they using if so?
