kb3epz
- Joined
- Jul 22, 2020
- Messages
- 5
So I just received my PSR- 800 back from Whistler yesterday afternoon.
I installed a new SD 16mb micro SD and setup the scanner per their instructions using the Whistler WS1080EZ Scan software 2.48 Bld 688.
I did a basic library load and everything worked perfectly. Was receiving trunked and conventional traffic no problem. About 30 minutes after powering up, the scanner died. No big, just needs new batteries. I didn't have any NiCad's charged, so I put regular batteries in. Powered it up and it immediately powers down due to low battery. Tried multiple batteries out of new packages. Same result. I plug the USB cable in and it powers up fine and starts scanning. However, it has no audio. I went through the forums searching PSR-800 no audio and tried the following:
1- Removing USB and batteries and held power and another button for at least 60 seconds. Did this multiple times. No change.
2- Restored factory defaults. No change.
3- Reformatted SD card and reinstalled personality. No change.
4- Reformatted SD card and installed factory default configuration. No change.
5- Reflashed CPU using the CPU Firmware Installer - Legacy Upgraded (CPUUpdater_Legacy_U4.8_BOOT2.0). No Change
6- Reflashed DSP version 4.8 using E-Z scan update. No Change.
7- Installed second SD Card. No Change.
I also did #1 after all the other steps I took as well. Not sure if the power and audio are related or not, but I figured I'd mention it.
Not sure what else to try at this point. The scanner was never hacked and was working before the upgrade. Got a clean bill of health from Whistler, I presume because it was in and out of their shop in a few days.
Pretty frustrated at this point. Since it's the weekend, I haven't contacted Whistler yet. Just seeing if anyone has any thoughts. Thanks in advance.
