SDS100/SDS200: Just purchased SDS100. Have some questions. :) (of course...).
sld
Thomasville, NC
Thanks for the advice. I might ought to stock up on the belt clips/door clasps... I'm rough on belt clips... :) Thanks for the tip on the DMR upgrade.
I haven't experienced the battery or battery cover clip issues (knock on wood). I use the external charger mostly, occasionally charging the battery while in the radio (usually when traveling). I have the leather case for the SDS100 which has a substantial swivel belt clip which has worked well. It has enough ventilation the scanner doesn't overheat.
