Kaufman County
Harold
Texas
They will use the Megahertz system for their Dispatch and flight following. The Dispatcher in the CareFlite Operations Center will usually advise them of the Ground Contact channel. Sometimes a VMed channel, a fire ground channel or a talkgroup. You really need to hear the dispatch, or be listening to the agency requesting them.
hiegtx
Dallas, TX
What raido frequencies do carefilte use in Kaufman County?
If you are referring ground ambulances, as opposed to the medevac copters that Harold covered, there is a ground ambulance talkgroup on TxWARN that can be used by CareFlite:
There is also a designated ground ambulance talkgroup on the Kaufman County system.
Para078
Tx.
Careflite uses a talk group on the Kaufman County system.
