I have a TK 7360 or 7180 model number slips my mind right now.
Anyways, I have 2 in a console one of them in the last week loses power upon key up when emergency lights activated or that’s how I got it to shutoff and the radio doesn’t turn back on. The way it turned back on for me is when I started to unscrew the console ( maybe lose wire) It then turned back on.
This was a factory install job just for an fyi
I looked to see if The antenna was on the rig.It was. (Did a radio check it was good)
I tighten up all the ground screws behind the driver seat
Checked the coax and antenna connection to the radio it was good and secured.
checked the power coming out or the radio it looked good.
radio looks fine doesn’t look like anything was spilled on it.
closed the console back up. Started to key up the radio , vehicle off, vehicle on, lights off, lights on, shoreline plugged in and not. Everything working just fine.
Just had one of those feeling so I opened up the console again playing around with the wire and the radio reset Again coming back on.
so I replaced the crimp connection.
Button up the console and did all the testing again and ita working. Still no issue yet with powering off or resetting
I just wasn’t sure If someone had an idea or a suggested if it happens again.
I’ll add some pictures
