Kenwood Tk 880 help
codymw623
Ebensburg PA
I have a kenwood tk 880 with the band split of 485-512mhz. Is it possible to change the band split to 450-490mhz. I tried programming the radio with this band split. the programming took but when i key the radio mic up i hear a loud beep and it wont transmit. Is it possible to change the band split. I always thought you were able to jump around the different band splits as long as it was a UHF or VHF board.
N4KVE
PALM BEACH, FLORIDA
While these radios are slightly flexible & can go up, or down 8-10 mhz, you are asking for too much. The 450-490 version will go down to about 442 mhz, so the most you could expect your radio to go down to would be about 475 mhz.
