Keyloading XG-75P… Cable needed ?
lbd1123
Is there an adapter KVL or KFD mini for the XG-75 ? Or would the standard programming cable load Keys…
K2NEC
39A
I keyload with KeyAdmin which just uses the programming cable. If you want to use a KVL you will need the 14002-0143-01 adapter which is rather expensive but NLT has a few in stock
lbd1123
Do you put the radio into key load mode from the radio. I am using a KFD Mini keyloader
