KNG-P150 Function buttons stopped working
Startree
Waretown NJ
Hi!
I have a KNG P-150. I managed to successfully program a channel bank with my computer.
All front keypad buttons worked prior to me programing.
When I went to switch banks I noticed the buttons no longer worked.
I opened the global settings but I can't make any changes.
I appreciate any help with this.
Onelick
100 yards west of the east branch of the Antietam
When in RES, go up to the top line under Options, make sure you have the correct radio highlighted. Then, on the top right there's a section titled "config" with "menu" and "buttons". Click on "Buttons" and it will open up a new, smaller window with the configuration for the button for which ever model radio you selected at the beginning.
Hope this helps,
Onelick
Startree
Waretown NJ
Thanks for your reply!
I made sure the correct radio is checked in options. But have not found any button menu
Sorry to be a PIA.
Startree
Waretown NJ
Here's some photos.
Startree
Waretown NJ
I managed to get the controls operating by sliding the functions from available to used in menu/controls.
Thanks for your help and this forum
Startree
Waretown NJ
Thanks for reply. Let me check on that. Also Even though it's working I don't think the radio has the power it should have. My feeling is it's something to do with programiing.
Startree
Waretown NJ
The P150 and the S version use that software. FW 1.6.1 and SW 1.2.0
Thanks, any thoughts on excessive battery use? With out doing a whole lot of transmitting I went through three clam shells yesterday. I've ordered a rechargeable batt but I'm thinking that won't solve my problem.
rsmith7799
Arroyo Grande, CA
So when I tech a class o the radios I tell the people "It's a computer with an antenna on top" The radio even if you don't scan, light is off and don't talk it will go through batteries like you said. You aught to see the batteries we use on a wildland fire her in CA.
The rechargeable WILL help.
As far as the power, each channel can be programmed to HI or LOW power.
Startree
Waretown NJ
Thanks, I'm just used to my GPH that I could transmit a lot during the day and get through with two clamshells.
