KPG111D v5.21 bug?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Latest firmware and software with a NX-200.
It appears that in a MDC1200 zone, you can not select MDC1200 in the ‘channel edit’ -> ‘Optional Signalling’ MDC1200 does not appear. Only DTMF and 2tone. I have set a random MDC120 ID before trying to select it in the channel edit window.
Has anyone else come across this? @kd4efm
I know the NX-x00 are near EOL, and likely not going to see another firmware/software release.
I may have to go backwards to software v4.70 and matching firmware (MDC1200 worked with this release)
Chris-KH2PM
Northern Harnett Co. NC
I'm running V5.00. I'm a new user of Kenwood NX-xxx series, by the way. I recently acquired an NX-300 for NXDN via a MMDVM ZUMspot and Jumbospot. I'm learning this CPS too.
Mine is also greyed out, but reading the help file, Optional Signaling (analog) selection is only for SELCAL, using DMTF, 2-Tone, or FleetSync.
I set up a conventional zone with analog channels. MDC-1200 is zone specific. In order to transmit and/or receive MDC1200, the zone has to be set up as such. First look under 'edit, zone information' and see if the signaling type is MDC-1200 at the top. Every channel in that zone will decode MDC-1200. Specific channels have to be set up for PTT ID BOT, EOT or both. This is done in Channel Edit, PTT ID (Analog).
Hope this helps.
kayn1n32008
Sector 001
Hope this helps.
Hmmm that makes sense to me, I just thought I had to select it in the drop down menu. Will dig into this and will report back shortly.
Chris-KH2PM
The drop-down menu to enable PTT ID is Channel Edit, PTT ID (analog). BOT = beginning of transmission. EOT = End of transmission.
Select OFF and the radio will not transmit PTT ID.
Chris-KH2PM
PTT ID (analog) will be greyed out if the specific zone is not set up for MDC-1200 signaling.
Also, under Edit, MDC-1200, turn on the checkbox for Caller ID Display for the receiving MDC ID to show up on your radio's display.
kayn1n32008
Sector 001
Also, under Edit, MDC-1200, turn on the checkbox for Caller ID Display for the receiving MDC tone to show up on your radio's display.
Thanks. I’m quite familiar with the NX-x00 series, I have not played with MDC1200 much(it’s annoying AF to listen to). I have an agency near me that uses MDC1200 to RTT, and have used both my NX-200 and NX-700 to display the MDC1200 transmissions, but was doing some experimenting with Fleetsync with my NX-200 and a TK-2212.
I just confirmed that you don’t select MDC1200 from the optional signalling drop down in the channel edit screen like you do with Fleetsync.
Thanks for your assistance.
