Thank you for posting those sweeps. It made me plot the older Larsen and Scan III just now and my results are very similar to yours, except for 700 MHz and up. Mine was a bit worse there, but no surprise due to my coax type and length of it. I use an NMO lip mount on the side of the hood near the passenger pillar.
Besides a sweep, over time I have switched back and forth between the older Larsen and Scan III in a suburban area. What is interesting, keeping the sweeps in mind, is that I have a slightly improved signal quality on weak signals ( via my ear ) while using the Scan III. I have also tested the two with a significantly reduced ground plane and there the Scan III pulls ahead in the sweep. The Scan III is different, but is it worth twice the price of the Larsen? If the mounting location has a compromised ground plane, or a short antenna was needed, I would say yes.
Still, even mounted on the side of my hood with an NMO lip mount, the new Larsen 150/450/758 may provide improvement. Plus, it offers that fancy spring. I'm $50 and a week away from finding out.
