Lcra p25
jbsarandolphmonitor
Air band monitoring JBSA-Randolph
Schertz, TX
Tg 12081 is UC Fire. In Schertz they have a tac like tg they call it Fire 1. It is tg 12097. I thought that all of the cities have the same kind of tgs. The all call tg idea might be what the LCRA is doing.
Here is a list of tgs that might be used for all call tgs. All of the tgs are showing up in my pro96com log.
12040 Live Oak Fire All Call
12054 Selma Fire All Call
12066 Converse Fire All Call
12080 Universal City Fire All Call
12094 Schertz Fire All Call
12110 Cibolo Fire All Call
Donald
texasemt13
CenTex DBA
Hunter, TX
Unknown site 120 in the LCRA P25 database is showing up on gps as being in the the Spring Branch area near 281 and 306.
You're referring to the location map in the RR database right?
If so, that is the default location for all the unknown sites for this system so far (search the other two also). Don't assume it's in Comal County just for that reason.
texasemt13
CenTex DBA
Hunter, TX
I might have some time today to root through this thread and compile everything into the database. It'll take some time but I know some stuff is missing.
I think I have most everything.
texasemt13 said:
Don, for your "Comal" site, I plugged in the CC you said was active and cannot get it from my office (like I can the Live Oak site).
Didn't hear a thing from this all day, and couldn't pick up a cc. Don, have you confirmed the cc and site number from listening to it or are you just seeing it in Pro96Com logs?
jbsarandolphmonitor
Schertz, TX
Pro96com is showing it as a neighboring site for the Live Oak site. It is also showing the old New Braunfels site. I can't hear site 120 from my location in Schertz.
Donald
NC5267
San Antonio
12080 I have only heard one time when the system first came online and I heard "Bexar Fire Alarm to UC Fire, Fleet Test" Never heard a reply. On one of the Converse Fire Tac channels I heard them doing training with Camelot and San Antonio Fire awhile back so city and county fire have access to the P25 system. Truck 1 could be anyone.
texasemt13
CenTex DBA
Hunter, TX
Ok, someone will correct me, but if I recall correctly, just because it is appearing as a neighbor does not mean it is broadcasting (as is the case with the New Braunfels site right now).
So, that might be why none of us can hear it, it's planned as a future site, or the site is down.
texasemt13
CenTex DBA
Hunter, TX
... so city and county fire have access to the P25 system. Truck 1 could be anyone.
This is possible through LCRA's VIDA switch, which can connect analog EDACS (hence the older 900MHz LCRA TRS and the LO TRS), digital EDACS (ProVoice; and supports ESK PV), and many other disparate types of systems and can connect them to a P25 system. That's how all of this is able to happen...
This is what I've been calling back door interoperability because you have to use some workarounds to be interoperable. I don't see San Antonio going P25 for awhile because they've have this capability through LCRA.
jbsarandolphmonitor
Schertz, TX
I know the last time i ran pro96com on the New Braunfles site site 122 was not showing up as a neighboring site anymore. If they are not using them why do they show up?
Donald
texasemt13
CenTex DBA
Hunter, TX
Since these are all computer controlled processes, it could be as simple as typing the information in to a program so it (the site) knows where to look for the neighboring sites... remember these things aren't linked by radio, but by data lines- the input has to be put in by a human at some point.
I've never programmed a trunking system from a SysAdmin side, only as a consumer trying to program the trunking radios side (... and then, only EDACS).
texasemt13
CenTex DBA
Hunter, TX
Thanks. It would be nice if the sites were online so we can find them.
Agreed. I tried to listen out for your "Comal" site again today, and it is not up. Considering we're experiencing better range with these 700MHz sites, I would have expected to hear it if it was online (and in Comal County).
NC5267
San Antonio
Don I posted a problem with the PSR 500 and the 700mhz band awhile back and how it shows two different freqs for the same control channel. For example it will show 770.28125 but will also show 770.284375 both with the same ID of 981. That may be what is going on with the 770.18125. I can't get anything on that here in Selma
KevinC
32D2T/957.282
I'm everywhere Focker!
I'm not sure why GRE put the 3.125 kHz step capability in their radios, they aren't used (yet) and the radios aren't selective enough to separate them from adjacent frequencies.
jbsarandolphmonitor
Schertz, TX
Cibolo and Schertz FD are working a grass fire on Cibolo FD Fireground tg 12112. I just submited it to the db.
Donald
jbsarandolphmonitor
Schertz, TX
A Cibolo officer was testing his radio on tg 12117. I am watching out for this tg to show up again so I can ID it.
Donald
