LED Strobe Light Interference
etihparg
Gilbert, Arizona
I have a Relm RMV25 (VHF) radio mounted on and ATV, using a Diamond nr770hnmo antenna. For safety there I have a 4 LED red strobe, and everytime the strobe flashes I get interference on the radio. Any suggestions on how to eliminate this?
Hit_Factor
Saint Joseph, MI
You'll probably need a different LED strobe. LED don't work well in garage door openers because the interference blocks the signal (315 & 319 Mhz roughly). Some LEDs are advertised as low RFI. Public safety LEDs are probably better at reduced RFI, so that may be something you could look at.
clbsquared
Isle of Wight County
Change your ground, put a filter in, change brand of LED. I would chmge the ground first, though.
And I feel the need to add that, LED's are not "Strobes". LED's are LED's and they "flash". Strobes are Strobes and they "flash".
12dbsinad
The only fix is to buy a better LED. Look into Whelen products. You'll pay more but all there products emit zero RFI. They test for this.
