Let’s make Florida a better place to monitor, new and updated data.
wise871
N.W. Florida
Over the last week many of you have probably noticed a lot of green updates in the state of Florida. What I have been doing is visually checking counties to see what is contained in each one. This way I learn every part of the state and how it is laid out. Besides working submissions I have been going from county to county looking things over and updating names, geotags, service tags and whatever might not look right. Don’t worry I’m not overhauling everything, most of it is just cosmetics and most of it is unnoticeable to the average user.
What I would like help in is making Florida’s database more up to date. This is where you come in, the area experts. I live in N.W. Florida so if I can hear it in my area, I can ID it and submit it. I don’t know what is good, outdated or incorrect in your areas. If everyone would look over there areas and see what is still valid or outdated, then please submit the information. I know I find something new or something has changed in my area monthly.
When you submit your information, please try to be as detailed as possible. If it is new information, try and submit it in the format that you see in the database with as much information as possible like user, tone, FCC info, description; “Sheriff Ch-1 Dispatch” service tag, etc or even a link. By providing detailed information means the submission gets processed a lot quicker because the admins are not searching where you got the info from. It’s hard to process a submission if it only contains a frequency and says Sheriff. Let us know what is used for and if it has a channel number or description assigned. Nothing worse than seeing 4 or 5 Police, Fire or Sherriff channels listed with no breakdown on what each is used for.
If you see frequencies that are no longer used then let us know that also. We can tag them as depreciated or delete them if there that old. Good examples would be, FCC search shows that it has expired (provided link if possible) or they moved over to a trunk system in the area and conventional is no loger used.
Still a lot of unknown frequencies out there to find and document. This is true with state agencies and new systems that are coming online. State agencies are pretty easy to locate if you search the internet and FCC for the information. A couple of good ones to hunt down are the department of corrections, juvenile detention facilities, Medevac and state parks. You would be surprised how many facilities they have scattered throughout the state and they use conventional frequencies. The part I enjoy about my scanner is finding and ID’ing new frequencies. If you find one, please make sure you can actually monitor it or you know for a fact it's active. Some of the States Communication Plans are way outdated.
I’m sure I could go on but you get the point. Seeing that Florida is one of the largest states and visited by many scanner hobbyists all year long, it would be great for everyone to have accurate information to reference when needed.
Again, we rely on you and the information is only as accurate as you provided.
Thanks for your time and help.
Dan
khoelldobler
now residing in Ocala, Florida since 1999
Wise871, your doing a great job ! I will be sure to continue to submit crucial info for my area of Ocala/Marion County as I have done in the past. It's important for all of our Florida friends to submit info only after they have truly confirmed what it is. Mis-information only causes agrivation to users of our database. Best of luck to all, and lets make Florida a better place to monitor :)
wise871
N.W. Florida
I just wanted to let everyone know we’ve been getting some great updates. I ask that when you submit information that you provided whatever details you can so we can understand what your submitting. Here are a few examples.
If you’re submitting a description change for a frequency or talkgroup, then let us know that freq/talkgroup is replaced/used by who? I would hate to replace a dispatch channel with a tac channel.
Another submission we had referenced that an old taxi channel was now being used by a medical transport company. When I check the FCC data it still reefers to the taxi company as the user. Then I have to decide if I change it or not.
Remember, I can’t hear what you’re monitoring so the information is based on what is submitted. Also there will be time were we need to private message submitters. Please make sure we can reach you if we have additional questions. Many of you have this disabled in your profile. Then the admin is stuck trying to figure out your submission and it won’t be worked as quickly as a well detailed submission. .
Again, thanks for the great work. Keep it up.
Dan
N4DES
Retired 0598 Czar ÆS Ø
South FL
I personally keep 813A updated as best as I can for the database even though others from time to time post incorrect information.
KE5TLF
MS Gulf Coast
Keep in mind FCC data is also only as good as the people maintaining it as well, and is quite flawed itself in many instances.
Bolt21
Spark Chariot Driver
Punta Piñal
Dan, this is STILL Yellow Cab. Complete with a lady hollerin' into the radio with a non-easy listening station blaring in the background. Had this as Yellow in my logs, and confirmed again a few moments ago.
Don't know why people do this crap, but there needs to be consequences for posting bogus info. If this was an honest mistake by the contributor, then I apologize.
wise871
N.W. Florida
Bolt21
Thanks for the update, it an easy fix. I didn’t update it because I was unsure of the info submitted. When I get home I will fix it. Someone was just trying to contribute to the database to help out. and sometimes mistakes are made, no biggie. If I have a question on a submission I will look up the users past history and if it’s somebody new, I will bump the submission against the FCC listings and the Florida forum. Many times I will find the answer right here in the forums. I will also PM the sender to ask additional questions. No harm done. If you would be so kind to submit the info for the cab company I will see it in the request queue and make the changes.
Thanks for pointing it out.
Dan
