Florida Power and Light
dave3825
Suffolk County NY
To anyone trying to monitor FP&L, the system is a mess and hopefully some of you, or anyone for that matter can help to clean it up by submitting the needed changes.
First 6 departments all share the same gps location with a 36 mile range
That gps location sets those 6 here around Port Canaveral which is Brevard County.
Fort Myers is about: 26° 38' 26" N / 81° 52' 22" W
Naples is about : 26° 8' 30" N / 81° 47' 42" W
etc
About 90 of the sites on this system have a 220 mile range sharing the same location leaving 5 sites in their actual areas of operation.
This post derived from this Sentinel: - Florida Power and Light with SDS100 scanning all sites
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
i will go in and clean this up - this was probably overlooked as the system was entered into the dB.
batdude
Moderator
I think I have the majority of the locations fixed. thank you for bringing this to our attention - dB accuracy is very important when using any type of location-based scanning.
that said.
I would most certainly only load this system into your scanner as a Favorite List type entry - and then remove all of the sites that are not anywhere near you. Since the talkgroup listings are very sparse for FPL, I would leave the radio in ID SEARCH mode rather than trying to zoom in on particular TGs -- I suspect that many of them are not accurate. At some point, the way we are grouping TGs on this system probably needs to be re-thunk ----- grouping into major geographical areas is probably not working out so well. Since there are a limited # of TGs that have been identified / verified, it may be easier to put them into a single table.
again - for now, I would most certainly only load the sites nearest you and leave it in ID SEARCH.
I am going to zoom into your picture above that shows the "ARCADIA" site - and that it has a 220 mile range. I don't know how Sentinel is translating "site range" but Arcadia only had a 20-ish mile range - I suspect the TG category range was driving this into the radio.
thx!
dave3825
Suffolk County NY
Thank you for looking into this and making changes so promptly.
Monitoring the Edgewater site found TG 508 606 and 607 and 65157 and 65190 65168 65148
If you can identify any of them, feel free to make submissions.
