Greetings,
As some may already know, liquidsoap does not function properly due to recent changes by the team at Liquidsoap. The issue becomes apparent when one updates past a certain version of liquidsoap (not sure which version, but the issue occured to me after trying to use it on Debian 12 or Ubuntu 24.04.1). The fix was pretty simple, really, all that needed changed was removing "icy_metadata="false"". I am not saying this will solve it for everyone else, but this worked for me.
Code:
#!/usr/bin/liquidsoap
# Example liquidsoap streaming from op25 to icecast
# (c) 2019, 2020 gnorbury@bondcar.com, wllmbecks@gmail.com
settings.log.stdout.set(true)
settings.log.file.set(false)
settings.log.file.path.set("")
settings.log.level.set(3)
settings.log.file.append.set(false)
# Make the native sample rate compatible with op25
set("frame.audio.samplerate", 8000)
input = mksafe(input.external.rawaudio(channels=2, samplerate=8000, restart_on_error=false, "./audio.py -u 23450 -x 4 -s"))
# Consider increasing the buffer value on slow systems such as RPi3. e.g. buffer=0.25
# Longer buffer results in less choppy audio but at the expense of increased latency.
# OPTIONAL AUDIO SIGNAL PROCESSING BLOCKS
# Uncomment to enable
# High pass filter
#input = filter.iir.butterworth.high(frequency = 200.0, order = 4, input_1)
# Low pass filter
#input = filter.iir.butterworth.low(frequency = 3250.0, order = 4, input_1)
# Compression
#input = compress(input, attack = 15.0, gain = 2.0, knee = 1.0, ratio = 3.0, release = 60.0, threshold = -24.0)
# Normalization
#input = normalize(input, gain_max = 6.0, gain_min = -6.0, target = -16.0, threshold = -40.0)
# LOCAL AUDIO
# Uncomment the appropriate line below to enable local sound
# Default audio subsystem
#out (input)
# PulseAudio
#output.pulseaudio(input)
# ALSA
#output.alsa(input)
# ICECAST STREAMING
# Uncomment to enable output to an icecast server
# Change the "host", "password", and "mount" strings appropriately first!
# For metadata to work properly, the host address given here MUST MATCH the address in op25's meta.json file
output.icecast(%mp3(bitrate=16, samplerate=22050, stereo=false), description="Police & Fire", genre="Public Safety", url="", fallible=false, host="changeme", port=80, mount="changeme", password="changeme", mean(input))
