Live MS Scanner Coming Soon.....
INDY72
Indianapolis, IN
Thanks to finding the info on the signal amp for my scanner, I should have an online scanner covering Southwest Mississippi by the end of this summer.
McReb
McComb, Ms
:D
When you get your scanner on line, please post in complete detail how we may receive it on our computers.
harley092355
TYLER, TEXAS
milf,
Great job on the live scanner-your input on the board is always of value......I am from Adams County, could you comment on the MHP in or around Natchez and Brookhaven-----does the MHP have a way to send a broadcast from Brookhaven to a car in the Natchez area.....Can I receive Brookhaven MHP in Natchez on my scanner or do they turn on some kind of repeater on and off in that area....I believe they have a repeater in the Doloraso area which is north of Natchez----do you know the frequency for that repeater??????Anything of value would be appreciated.....Thanks
McReb
McComb, Ms
Not Milf but yes Brookhaven MHP does have a repeater tower in Adams Co. and it operates using District 9 regular frequencies of 42.08, 42.30, 42.20 (private car 2 car) and you might want to also put in 45.32 which a MHP repeater statewide freq.
Brookhaven MHP to communicate with their western units does activate the tower in Adams Co. to do so. I hope this helps.
McReb
McComb, Ms
I think you are right. I think they activate that tower when they know that the unit is on that side of the district.
With my home scanner [780] I hear, for instance, "Brookhaven all units; the radio will be 10-6 a few." I hear it twice. Once over the East side tower quit strong and then a little weaker from the Natchez tower.
INDY72
Indianapolis, IN
They uses the repeater as a glorified car to car 80 percent of the time, but do use it when the main tower goes down for repairs, etc,...
As for picking up in Natchez, MHP has satelite towers all over the district and using both microwave, and landline can switch to the tower where the unit is calling from. Also dont forget the UHF Point to Point transmitters all over each district. And most importantly monitor Statewide Lo Band as all MHP Units call in to the local SO's on a regular basis for 27/28/29 checks and will have District HQ call the SO's to have them turn the intoxilizers on.
INDY72
Indianapolis, IN
OK here is the most useful for Natchez:
The 911 District TRS
Used by NPD, FDN, NDPW, Transit, VFD's.
Fire Department Natchez: 154.4300 Used to tone out all VFD's.
Adams SO: 453.4750 (Zebra Chan) Primary Dispatch, 154.7400 (North Chan) Primarily Detectives/Narcotics.
AMR: 155.3250 Primary Dispatch
NRMC: 155.2350 ER Ops
Metro/Rural: 151.0550 Primary Dispatch, 158.8200 Secondary
155.3400 Statewide ER Net except NRMC
Vidalia PD: 155.5950
Vidalia FD: 154.3850
Concordia SO: 155.5650 Primary, 154.8000 Secondary
Concordia moved its primary SO from Ferridey to Vidalia, so now all comms are run through SO Vidalia.
Ferridey PD: 155.6550
MHP: 42.0800 District 9 Dispatch, 42.3000 Troop M Mobiles.
42.2000 Car to Car
45.3200 Statewide Repeater Net
42.8400 Supervisors
MS Dep't. Wildlife, Fisheries, & Parks (F&W): Primarily Uses SatComms now but still uses 45.000 and 45.0400 for car to car, and 45.2200 to talk to the SO.
MS Forestry Commission: 151.4150 All SouthWest District Units to Brookhaven on each county's repeater.
151.4750 MFC Aircraft.
Natchez Trace: 171.6750 Rangers F-1, 171.7750 Rangers F-2
F-3, and F-4 are still unknown to me so if you hear them used please let me know.
Louisianna Statewide TRS Ferridey Cell:
LSP Troop E:
2576 Dispatch
2608 F-2
2640 Tactical
2704 Car to Car
2768 Narcotics
2800 CSI/Detectives
2896 LSP 1
2928 LSP 2
2864 DPS Net
DNR Region 6:
30768 Dispatch
30800 Patrol
30896 DNR Net
30928 DNR Car to Car
DEQ Northeast Region:
12944 Base
12976 F-2
13008 F-3
13040 F-4
DOT Enforcement Region 58:
10064 Dispatch
10128 Communications Devision
DOT Work Net:
10000 Main
10032 Aux.
10160 Traffic Services
10192 Maintanance
Federal TG's:
6960 USCG
7024 USCG
34960 USCG Spill Response
34832 FBI Taskforce
Emergency Management District E:
21008 LEMA
DPS Mutual Aid Statewide:
5904 F-1
5936 F-2
Unknown as to which of the LSP Taskforce chans is used in Concordia.
Red Cross:
33712
National Gaurd:
21072 Ops
21104 Security
Unknown which ABC chan is used in Concordia.
harley092355
TYLER, TEXAS
STATEWIDE LOW-BAND USED TO BE 45.10----IS THIS STILL THE CASE FOR LOW-BAND STATEWIDE AS STATED EARLIER IN ONE OF THE THREADS.....
INDY72
Indianapolis, IN
Statewide Lo Band is 45.2200 MHz, Statewide Hi is 155.4900 MHz, and statewide Hi Car to Car is 155.7300 MHz
45.1000 MHz was used as Lo Band Dispatch by many SO's as are the following: 45.1400, 45.4200, and 45.1800. Very few of the SO's still use Lo band, except as backup for thier Hi band chans. Notable exceptions are as follows: Copiah County-45.1400 Ops/45.2600 Car to Car, Scott County which has reupped for lo band 45.1400/45.2600.
The mobile freq counterpart to 45.1000 is 45.3400.
INDY72
Indianapolis, IN
Here is the whole Lo Band Piring:
45.1000/45.3400
45.1400/45.2600
45.1800/45.3000
45.4200/45.3800
For EOC/Civil Defense:
F-1: 45.9200
F-2: 45.9600
F-3: 46.0000
F-4: 46.0400
Commonly paired in F-1/F-2, or F-1/F-3.
INDY72
Indianapolis, IN
Oh and almost forgot:
Statewide Lo Band PD Net:
45.4600 This is still used in many samall communities, though now is used as backup to Hi Band.
INDY72
Indianapolis, IN
Update for online scanner
Latest Update:
Expect first rial runs in late July.
Will be broadcast streaming but can't do 24/7.
Will be using Shoutcast to broadcast: www.shoutcast.com
Will use WinAmp 1 to send in to the server, and I use WinAmp 5 to monitor.
There are several live scanners on Shoutcast, including Atlanta 800, DeKalb County, etc.. Stamford, CT's EDACS is on there.
More as it gets growing.
INDY72
Indianapolis, IN
Oh and for the Natchez area, I forgot a very important one:
39.5000 Interop for MHP with LSP. Most of the MHP units in District 9 have this programmed in the mobiles so they can talk to LSP units. Many Natchez PD units also still use hi band to communicate to VPD, and CCSO.
matthewtomek
Live Audio Admin
Memphis, TN
Re: Update for online scanner
milf said:
Latest Update:
I checked out the shoutcast website. Maybe its just me, but I don't understand what all you have to do to host something like this. If it is easy, I might do something for my County Fire Dispatch for our former FFs that have moved off. I have a spare scanner that is available. Shoot me a PM or e-mail, MILF or whoever else that can explain it to me.
Thanks,
Matthew Tomek
mtomek@bellsouth.net
INDY72
Indianapolis, IN
In a nutshell: Get a scanner that has a PC interface port,.. get the software to run siad scanner, get winamp 1, then dl the software from shoutcast to run online with them. If you have a good pc and it can handle being dedicated to the scanner then even better. As for me, I will be running only for say six or so hours a night till I can get a second line or they actually get a DSL server for my county. Luckily the PRO 2052 has a serial interface port making it easy to do this. The way to do it for maximum benefit would be to buy server space somewhere and run the scanner through the server, or if you have a friend you can run it through would be even better. But for those of us who cant quite rig out that big a deal then just run with what you can and if you can set up for a 24/7 run then more power to you, as soon as I can dig up all my info i will zip you an e-mail.
McReb
McComb, Ms
I confess I am dumb
I went to SHOUTcast but find nothing to lead me to the scanner listening area. Where do I go and how do I get there?
Thanks.
INDY72
Indianapolis, IN
McReb:
Do a search for scanners.. there are like 150 listed there, PS, Rail, Foriegn, and Airport ones, plus a couple of shortwave ones.
www.shoutcast.com then go to the search bar they have, type in scanner.
