LMRN Technical Data Discussion
VA3ADP
Mississauga, Ontario Canada
Logged some traffic today on TG 2058 with my SDS200 in discovery trunk mode. It was clear P2 traffic with two techs talking if they could see their RID's Im not sure what 2058 would equate to on the old system.
VA3ADP
Seeing a bunch of encrypted traffic off of Britannia with TG 696. RID's are in the 4021×× range.
Also saw group 1011 key up. Audio but no voice.
Muxlow
Super Secret
Middlesex County
BMR was out at Lambton EMS HQ yesterday doing some radio installs. Saw groups 21066 20605 21650 have affiliations from the same radio id. Today group 20601 was active with AES in use.
Radio ID was 750022, 750080
Heard them on FleetNet doing Emergency button testing on some ambulances, then on 4 portables. So good assumption these are EMS groups/id's since it was at the same time they were doing those tests.
VA3ADP
I've seen 2051 and 2052 active. Both Phase II and in the clear. Both would convert to Police Common and Fire Common.
I saw 19114 pop up today also and totally encrypted. Not sure what that coverts to.
Ive also been seeing a ton encrypted traffic on 696. Not sure if this is perhaps OPP?
icarus1963
Brantford, Ontario
Getting a good signal and tone on 142.380. Quite possibly the Caledonia tower, as that is the ACC for FleetNet.
If anyone else can confirm this, that would be great.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Likely it is as it is identifying as King City primary FleetNet CC site here in Toronto.
ATCTech
142.140 now active with the 1038 Hz tone and excellent signal level here west of Toronto. Based on recent observation of 142.380 likely being Cayuga I would speculate this one is King City.
She's slowly gaining traction guys....
ATCTech
As there are no 142.880 FleetNet assignments to date, I suspect if you were hearing digital traffic on 142.880 in fact that was the South Simcoe PD NXDN system on 142.8825. Perfectly receivable from the Toronto area, but fully encrypted and not P25.
That system does not use the standard 15 kHz channel spacing in that band so the "steps" aren't going to fit into what we're used to calculating. A typical scanner isn't going to display the proper center frequency but it's bandwidth will be wide enough to receive the slightly shifted (2500 Hz) carrier frequency.
Standard 15 kHz steps in Fleetnet use 142.845, 142.860, 142.875, 142.890 etc. so 142.880 is invalid.
Here's what it looks like on the radio spectrum. Note the Fleetnet activity on 142.875 and 142.890 (then 142.905) on either side of it.
Make sense?
"Now back to our regular programming already in progress...."
ATCTech
142.800 now transmitting the 1038Hz P25 tone. Based on current alternate Fleetnet CCs and the signal strength I'm seeing my guess would be the Hamilton/Charlton site.
mbstone99
Hamilton, Ontario
I have been running DSD+ on this all evening and along with the 1038Hz P25 tone I have been seeing this in the data stream.
MAC_ACTIVE Group Voice Channel User Slot#2 PRI1 TG=1 RID=1
MAC_ACTIVE Group Voice Channel User Slot#1 PRI1 TG=1 RID=1
Matt
gary123
Got new EMS hit last night. Weak but from Middlesex area.
772.05625 PL 131.8
gary123
Matt
What your seeing is the normal 'Idle' test for the site. Both timeslots are active with the 1038 Hz tone. A radio on the site would hear the tone no matter what slot is entered or assigned.
DSD should also provide a Site ID and some info on the CC.
IdleMonitor
Judging by the frequencies posted in this thread and if I've followed along correctly, this frequency should round out all the VRs for EMS if it's anything like fleetnet.
771.84375 RM 110.9 PL MOH 700VR1 VR Mobile Repeater 1 FMN EMS Dispatch
771.89375 RM 127.3 PL MOH 700VR2 VR Mobile Repeater 2 FMN EMS Dispatch
772.05625 RM 131.8 PL MOH 700VR3 VR Mobile Repeater 3 FMN EMS Dispatch
772.13125 RM 173.8 PL MOH 700VR4 VR Mobile Repeater 4 FMN EMS Dispatch
773.03125 RM 136.5 PL MOH 700VR5 VR Mobile Repeater 5 FMN EMS Dispatch
772.05625 PL 131.8
gary123
Idle 772.13125 is OPP BEAT01.
my current summary is this
773.03125 RM 136.5 PL MOH 700VR5 VR Mobile Repeater x FMN EMS Dispatch
771.74375 RM 67.0 PL OPP VR01 Mobile Repeater
772.13125 RM 88.5 PL OPP BEAT01 Mobile Repeater
772.14373 RM 91.5 PL OPP BEAT02 Mobile Repeater
772.15625 RM 94.8 PL OPP BEAT03 Mobile Repeater
771.88125 RM xxx.x PL MTO unknown name
My belief is that the available 700 DVRS freq were assigned a sequential individual PL for each frequency. If so then PL tones
69.3, 71.9, 74.4, 77.0, 79.7 and 82.5 may also be OPP related DVRS or 700 simplex frequencies. K9, TRU, VIP, ERU type of use.
PL tones 100.0, 103.5 and 107.2 could be anything or unused?
PL tones 114.8, 118.8 , and 123.0 should be MOH assignments
This is only speculation on my part but it does seem to account for the lack of duplication of PL tones.
mikewazowski
Forums Manager
Oot and Aboot
