Loading keys xts2500 fail
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
I just got a 8 algo ucm for my xts2500.
Installed the keypad, plugged in my t3011dx and I get fail on the loader. I've setup everything up in cps that I did with my xts5000s (they all load fine). I was under the impression that maybe because the xts2500 had adp in the flash I went ahead and reflashed the radio with hardware encrypt and left out adp because the ucm has adp. Still a no go loading keys. I'm at a loss here.
Anyone have any input?
Radio has latest firmware that I need, ucm fw is latest as well.
Sent from my SM-G920V using Tapatalk
rbrtklamp2
Dupage County, Illinois
Have you changed the settings in the CPS to hardware encryption instead of software. Its a small step but often over looked. If thats not the problem come back and we'll try again. :) . I had the same problem with a 5000 a while back and that was my problem.
Sent from my SM-N910V using Tapatalk
SirJ
That's the first thing I did. As of now it's only hardware because I reflashed it with a different flashcode. When I get home in about 15min I'll post up the flashcode.
SirJ
Flashcode
RayAir
Is this a key management issue? You don't have CKR selected in CPS, correct?
You'll need to use PID since you're using an old KVL if you haven't already tried this.
BigLebowski
Piedmont NC
You can and should have both PID and CKR checked if you plan to evernload anything or have anything loaded with a KVL3000+. Make sure you have the appropriate number of slots set up in the codeplug for the number of keys you are loading and you are loading into the correct slots.
Failing that, make sure your cable and/or hirose adapter are not damaged. I’ve had some radios where I’ve had to tightly hold the adapter against the radio to get it to take the keys.
SirJ
I have 3 keys in the kvl, slot 0, 1 & 2
Im cps slot 0,1,2 for each key
BigLebowski
Piedmont NC
I’m sure you know this but on the radio it will be 1, 2, 3. When you load the keys it will be 0 to 1, 1 to 2, 2 to 3. Again, I would check your cable and/or adapter.
BigLebowski
Piedmont NC
Disregard this.. not sure what I was thinking but I went back into one of my codeplugs and you are doing it right.
SirJ
Anyway I can just send you my cpg and see if everything is right. If a xts2500 cant be loaded why do they offer a secure keypad that dont load keys...Is it just for a wow factor......im pretty pissed I spent a bit of money for looks and not use.
rbrtklamp2
You can send me yoir cp if you like I have a xts2500 loaded with a bunch of keys they do work
