- Joined
- May 20, 2020
- Messages
- 93
Searching through the forums, I see this conversation come up from time to time, and the general response is "build off-center fed dipole" antenna found here: Homebrewed Off-Center Fed Dipole - The RadioReference Wiki
The thing is, I don't fully grasp all of those concepts, and quite honestly, I'm looking for a "plug and play" solution.
The stock antenna gets me 99.9% of what I want to hear in my major metro area, I'm just looking to see if I can improve some of the P25 communications. I primarily monitor 460-470MHz, and lots of 800MHz P25. I would like to keep my options open with a wide band antenna.
Is this a viable option? Is there something better maybe a little less expensive (I understand, you get what you pay for)?
Would something like this with an SMA-BNC connector be a noticeable improvement placed high up?
I'm not a die-hard feed provider, this is for my desk scanner that I keep on while I'm working if I want some background noise.
Any recommendations under $100 are greatly appreciated.
AOR MA500 - Receiver Scanner Mobile Antennas
25MHz-1300MHz Wideband Receive Magnetic Mount Mobile Whip Antenna, 28in height w/ 13 Ft of RG-58/U Coax Cable, BNC Male Connector Installed.
theantennafarm.com
