Ok, so after 229 views and no takers, lol, maybe someone can help me from this point. Here's my specific issue. I set up a "P25 System" and entered the control frequencies for the tower that I think is closest to my house. I then set up a talk group under that system and then entered the talk group ID's for what I want to listen to. The scanner says it is receiving data on the CC, but I never hear any audio. I have set up systems for every tower within 50 miles of my house with same result. I feel like I am close to getting it set up correctly, but obviously, I'm still missing something. Any ideas?
Thanks!!
JKS,
I'm not in your state, but I'll give it a shot.
You say that you have a BCD396. Is that the first version, BDC396T, or it's replacement, the BCD396XT.
Are you using software? Or programming manually via the keypad. If you are using software (which program?), if you'll post your programming file, I'll take a look at it. To do that, you need to use a file type acceptable on the forums. But you can work around that.
[FONT="]To upload your file, to the Forums, you must change the file extension to one acceptable per forum requirements. To do that, note where your file is saved on your PC.
Using Windows Explorer, find the file.
There are two ways to do this. You can either change the file extension itself, or compress the file using
7-Zip or other file utility. The *.zip file extension can be attached to a post and uploaded to the Forums.
[/FONT]
[FONT="]In the instructions below, I am using the *.996 file extension, which is what FreeSCAN uses. If you are using something else, your base file extension may be different, but you need to rename it as noted below. ProScan files use a *.txt extension, so no renaming is needed. Be sure and note what program you used.
[/FONT]
[FONT="] Alternate method: Using Windows Explorer, rename your file one of these two ways:
For illustration, let's call your exported file '
MyFile.996' (without the quotes).
<Right><Click> on the file & choose Rename from the pop-up menu.
You can then rename your file to
MyFile.txt, or
MyFile.996.txt in order to attach it to a post. Whoever views the file will need to reset the file name back to
MyFile.996, then it can be imported into FreeSCAN for viewing.[/FONT]
Edit: I see you replied to wtp with the scanner model while I was typing.
