SDRTrunk Losing audio
dave3825
Suffolk County NY
I am running the latest version on Win 10 64 bit with Intel i7 4790 @3.60Ghz and 8gb ram. It will produce audio for about 4 hours and then stops. The tg's that I have set to listen and record seem to keep working as I can listen to recorded audio thru trunking recorder. Just stops playing audio for anything set to listen.
Any ideas?
tomcat2702
What does the console output say? Usually that will give some indicator on what the issue might be.
jjbllitz
Baltimore, Ohio
There is a google group for SDRTrunk. Someone there recently posted the same issue, although his stopped after only 20 minutes or so. The fix was a memory reservation setting for Java that needed to be set.
dave3825
Suffolk County NY
Below is what's listed in the window. It has been running for 3 days uninterrupted.
0.5.0 Alpha 6 Memory Issue
I posted in that group 7 days ago and yielded no replies there. I would like to try to "add more memory to the JVM thats the -Xmx option" but have not a clue where you do that.
I looked at the op's window and its has memory errors. My window does not list any memory errors and after running 3 days straight, it is using 1332mb of ram and 9 percent CPU. Mine does list 1 error about RTL2832 tuner type, but then it found the Airspy. The other error is for broadcastify config, which I do not use.
Where might I change this JVM memory setting?
My window contents
19:19:44.769 INFO i.g.d.icon.IconModel - loading icons file [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml] [11MB/124MB 9%]
19:19:44.774 INFO i.g.d.icon.IconModel - Icons file not found at [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml] [11MB/124MB 9%]
19:19:44.978 INFO i.g.d.log.ApplicationLog - Application Log File: C:\Users\Preferred Customer\SDRTrunk\logs\sdrtrunk_app.log [19MB/124MB 15%]
19:19:45.016 INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.5.0-alpha6 [22MB/124MB 18%]
19:19:45.016 INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 6.3 [22MB/124MB 18%]
19:19:45.016 INFO i.g.d.log.ApplicationLog - Build Timestamp : 2020-10-26T04:29:57.816-0400 [22MB/124MB 18%]
19:19:45.016 INFO i.g.d.log.ApplicationLog - Build-JDK : 15 (BellSoft 15+36 [22MB/124MB 18%]
19:19:45.017 INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 4.4.0-193-generic [22MB/124MB 18%]
19:19:45.017 INFO i.g.d.log.ApplicationLog - [22MB/124MB 18%]
19:19:45.017 INFO i.g.d.log.ApplicationLog - ******************************************************************* [22MB/124MB 18%]
19:19:45.017 INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [22MB/124MB 18%]
19:19:45.018 INFO i.g.d.log.ApplicationLog - **** website: DSheirer/sdrtrunk *** [22MB/124MB 18%]
19:19:45.018 INFO i.g.d.log.ApplicationLog - ******************************************************************* [22MB/124MB 18%]
19:19:45.019 INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [22MB/124MB 18%]
19:19:45.019 INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 10 [22MB/124MB 18%]
19:19:45.019 INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [22MB/124MB 18%]
19:19:45.019 INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [22MB/124MB 18%]
19:19:45.019 INFO i.g.d.log.ApplicationLog - Host CPU Cores: 8 [22MB/124MB 18%]
19:19:45.019 INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 1 GB [22MB/124MB 18%]
19:19:45.020 INFO i.g.d.log.ApplicationLog - Storage Directories: [22MB/124MB 18%]
19:19:45.020 INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\Preferred Customer\SDRTrunk [23MB/124MB 18%]
19:19:45.020 INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\Preferred Customer\SDRTrunk\logs [23MB/124MB 18%]
19:19:45.022 INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\Preferred Customer\SDRTrunk\event_logs [23MB/124MB 18%]
19:19:45.022 INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\Preferred Customer\SDRTrunk\playlist [23MB/124MB 18%]
19:19:45.022 INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\Preferred Customer\SDRTrunk\recordings [23MB/124MB 18%]
19:19:45.023 INFO i.g.d.util.ThreadPool - Application thread pool created with [8] threads [23MB/124MB 18%]
19:19:45.030 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\Preferred Customer\SDRTrunk [5MB/124MB 4%]
19:19:45.037 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties] [6MB/124MB 4%]
19:19:45.037 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties] [6MB/124MB 4%]
19:19:45.055 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\Preferred Customer\SDRTrunk\settings\settings.xml] [6MB/124MB 5%]
19:19:45.279 INFO i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations [10MB/27MB 40%]
19:19:45.371 INFO i.g.d.s.t.TunerManager - LibUSB API Version: 16777478 [12MB/27MB 46%]
19:19:45.372 INFO i.g.d.s.t.TunerManager - LibUSB Version: 1.0.22.11312 [12MB/27MB 46%]
19:19:45.512 INFO i.g.d.s.t.TunerManager - discovered [11] attached USB devices [12MB/27MB 46%]
19:19:45.517 INFO i.g.d.s.t.TunerManager - USB Bus [1] Device [8087:8008] Hub Device [12MB/27MB 46%]
19:19:45.517 INFO i.g.d.s.t.TunerManager - USB Bus [3] Device [8087:8000] Hub Device [12MB/27MB 47%]
19:19:45.521 ERROR i.g.d.s.t.TunerManager - couldn't determine RTL2832 tuner type [12MB/27MB 47%]
io.github.dsheirer.source.SourceException: couldn't open device - check permissions Linux: udev.rule? , or Windows: reinstall Zadig? [LIBUSB_ERROR_ACCESS]
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerController.identifyTunerType(RTL2832TunerController.java:346)
at io.github.dsheirer.source.tuner.TunerManager.initRTL2832Tuner(TunerManager.java:476)
at io.github.dsheirer.source.tuner.TunerManager.initTuner(TunerManager.java:333)
at io.github.dsheirer.source.tuner.TunerManager.initTuners(TunerManager.java:148)
at io.github.dsheirer.source.tuner.TunerManager.<init>(TunerManager.java:79)
at io.github.dsheirer.source.SourceManager.<init>(SourceManager.java:46)
at io.github.dsheirer.gui.SDRTrunk.<init>(SDRTrunk.java:167)
at io.github.dsheirer.gui.SDRTrunk.main(SDRTrunk.java:624)
19:19:45.530 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] Unknown Device - Class 0 [12MB/27MB 47%]
19:19:45.530 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [8086:8C31] Hub Device [12MB/27MB 47%]
19:19:45.531 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [413C:2111] Unknown Device - Class 0 [12MB/27MB 47%]
19:19:45.531 INFO i.g.d.s.t.TunerManager - USB Bus [3] Device [8086:8C26] Hub Device [13MB/27MB 49%]
19:19:45.532 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [0764:0501] Unknown Device - Class 0 [13MB/27MB 49%]
19:19:45.571 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [1D50:60A1] LOADED: Airspy 04A464C8-342F810B Max Rate:320000000 bps [14MB/27MB 55%]
19:19:45.572 INFO i.g.d.s.t.TunerManager - USB Bus [1] Device [8086:8C2D] Hub Device [14MB/27MB 55%]
19:19:45.573 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [1965:001A] Communications Device [14MB/27MB 55%]
19:19:45.573 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [046D:C52F] Unknown Device - Class 0 [14MB/27MB 55%]
19:19:45.574 INFO i.g.d.s.t.TunerManager - ------------------------------------------------------------- [14MB/27MB 55%]
19:19:45.574 INFO i.g.d.s.t.TunerManager - USB Bus - Potential Maximum Data Rates [14MB/27MB 55%]
19:19:45.579 INFO i.g.d.s.t.TunerManager - USB Bus [2] Rate [320000000] bits per second [15MB/27MB 57%]
19:19:46.546 INFO i.g.d.p.PlaylistManager - Loading playlist [C:\Users\Preferred Customer\SDRTrunk\playlist\default.xml] [14MB/30MB 49%]
19:19:46.693 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [15MB/30MB 50%]
19:19:47.234 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [27MB/42MB 66%]
19:19:52.293 ERROR i.g.d.g.p.s.StreamingEditor - Unable to refresh broadcastify stream configuration(s) [67MB/129MB 52%]
19:20:00.717 INFO i.g.d.a.c.m.JmbeAudioModule - Loading JMBE library from [C:\Users\Preferred Customer\SDRTrunk\jmbe\jmbe-1.0.7b.jar] [138MB/220MB 62%]
19:20:00.730 INFO i.g.d.a.c.m.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.6 [138MB/220MB 63%]
19:20:00.730 INFO i.g.d.a.c.m.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available [138MB/220MB 63%]
19:20:00.753 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [6000000.0] providing [240] channels at [25000.0] Hz each [139MB/220MB 63%]
msingewald
Norwalk, CT
Look at the bold text below:
Now go to the sdr-trunk.bat file that you use to start the program, right click and choose edit. Scroll down to the following line:
@rem Add default JVM options here. You can also use JAVA_OPTS and SDR_TRUNK_OPTS to pass JVM options to this script.
set DEFAULT_JVM_OPTS=
Change it to this:
set DEFAULT_JVM_OPTS="-Xmx4096M"
See how that works.
dave3825
Suffolk County NY
Thanks for replying. I set it as you said at fired it back up right now. Going to let it run and see what she does today. I was looking for errors and I completely missed that it was referencing 1 gb.
dave3825
Suffolk County NY
So I made the change and am sad to say it still drops audio. Started at 10 30 am and right now there is no audio.
Task man shows 1132mb of ram in use and 19 on the cpu.
10:31:19.704 INFO i.g.d.icon.IconModel - loading icons file [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml] [11MB/124MB 9%]
10:31:19.710 INFO i.g.d.icon.IconModel - Icons file not found at [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml] [11MB/124MB 9%]
10:31:19.898 INFO i.g.d.log.ApplicationLog - Application Log File: C:\Users\Preferred Customer\SDRTrunk\logs\sdrtrunk_app.log [19MB/124MB 15%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.5.0-alpha6 [22MB/124MB 18%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 6.3 [22MB/124MB 18%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - Build Timestamp : 2020-10-26T04:29:57.816-0400 [22MB/124MB 18%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - Build-JDK : 15 (BellSoft 15+36 [22MB/124MB 18%]
10:31:19.935 INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 4.4.0-193-generic [22MB/124MB 18%]
10:31:19.935 INFO i.g.d.log.ApplicationLog - [22MB/124MB 18%]
10:31:19.935 INFO i.g.d.log.ApplicationLog - ******************************************************************* [22MB/124MB 18%]
10:31:19.936 INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [22MB/124MB 18%]
10:31:19.936 INFO i.g.d.log.ApplicationLog - **** website: DSheirer/sdrtrunk *** [22MB/124MB 18%]
10:31:19.936 INFO i.g.d.log.ApplicationLog - ******************************************************************* [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 10 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host CPU Cores: 8 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 4 GB [23MB/124MB 18%]
10:31:19.938 INFO i.g.d.log.ApplicationLog - Storage Directories: [23MB/124MB 18%]
10:31:19.938 INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\Preferred Customer\SDRTrunk [23MB/124MB 18%]
10:31:19.938 INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\Preferred Customer\SDRTrunk\logs [23MB/124MB 18%]
10:31:19.940 INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\Preferred Customer\SDRTrunk\event_logs [23MB/124MB 18%]
10:31:19.940 INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\Preferred Customer\SDRTrunk\playlist [23MB/124MB 18%]
10:31:19.940 INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\Preferred Customer\SDRTrunk\recordings [23MB/124MB 18%]
10:31:19.949 INFO i.g.d.util.ThreadPool - Application thread pool created with [8] threads [5MB/124MB 4%]
10:31:19.949 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\Preferred Customer\SDRTrunk [5MB/124MB 4%]
10:31:19.955 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties] [5MB/124MB 4%]
10:31:19.955 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties] [5MB/124MB 4%]
10:31:19.973 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\Preferred Customer\SDRTrunk\settings\settings.xml] [6MB/124MB 4%]
10:31:20.179 INFO i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations [10MB/27MB 39%]
10:31:20.266 INFO i.g.d.s.t.TunerManager - LibUSB API Version: 16777478 [12MB/27MB 45%]
10:31:20.266 INFO i.g.d.s.t.TunerManager - LibUSB Version: 1.0.22.11312 [12MB/27MB 45%]
10:31:20.419 INFO i.g.d.s.t.TunerManager - discovered [10] attached USB devices [12MB/27MB 45%]
10:31:20.438 INFO i.g.d.s.t.TunerManager - USB Bus [1] Device [8087:8008] Hub Device [12MB/27MB 45%]
10:31:20.439 INFO i.g.d.s.t.TunerManager - USB Bus [3] Device [8087:8000] Hub Device [12MB/27MB 45%]
10:31:22.094 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 Max Rate:38400000 bps [13MB/27MB 51%]
10:31:22.095 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [8086:8C31] Hub Device [13MB/27MB 51%]
10:31:22.096 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [413C:2111] Unknown Device - Class 0 [13MB/27MB 51%]
10:31:22.097 INFO i.g.d.s.t.TunerManager - USB Bus [3] Device [8086:8C26] Hub Device [13MB/27MB 51%]
10:31:22.098 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [0764:0501] Unknown Device - Class 0 [13MB/27MB 51%]
10:31:22.135 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [1D50:60A1] LOADED: Airspy 04A464C8-342F810B Max Rate:320000000 bps [14MB/27MB 52%]
10:31:22.161 INFO i.g.d.s.t.TunerManager - USB Bus [1] Device [8086:8C2D] Hub Device [14MB/27MB 54%]
10:31:22.196 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [046D:C52F] Unknown Device - Class 0 [14MB/27MB 54%]
10:31:22.209 INFO i.g.d.s.t.TunerManager - ------------------------------------------------------------- [14MB/27MB 54%]
10:31:22.209 INFO i.g.d.s.t.TunerManager - USB Bus - Potential Maximum Data Rates [14MB/27MB 54%]
10:31:22.213 INFO i.g.d.s.t.TunerManager - USB Bus [2] Rate [358400000] bits per second *** WARNING *** [14MB/27MB 54%]
10:31:22.214 WARN i.g.d.s.t.TunerManager -
* WARNING: the combined data rates of tuner(s) on USB bus(es) above can potentially saturate or exceed
* the maximum USB 2.0 data rate of 480 Mbps. This can cause data loss and severely impact decoding
* performance resulting in missed calls and stuttering audio. Recommend moving tuner(s) to other
* USB ports/buses to better balance data rates across available USB buses.
****************************************************************************************************** [14MB/27MB 54%]
10:31:23.108 INFO i.g.d.p.PlaylistManager - Loading playlist [C:\Users\Preferred Customer\SDRTrunk\playlist\default.xml] [14MB/30MB 47%]
10:31:23.258 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [20MB/30MB 68%]
10:32:05.032 ERROR i.g.d.g.p.s.StreamingEditor - Unable to refresh broadcastify stream configuration(s) [55MB/89MB 62%]
10:32:12.913 INFO i.g.d.a.c.m.JmbeAudioModule - Loading JMBE library from [C:\Users\Preferred Customer\SDRTrunk\jmbe\jmbe-1.0.7b.jar] [107MB/182MB 58%]
10:32:12.924 INFO i.g.d.a.c.m.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.6 [107MB/182MB 59%]
10:32:12.924 INFO i.g.d.a.c.m.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available [107MB/182MB 59%]
10:32:12.941 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [6000000.0] providing [240] channels at [25000.0] Hz each [108MB/182MB 59%]
10:32:12.974 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [117MB/182MB 64%]
10:32:13.805 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [258MB/312MB 82%]
10:32:14.841 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [259MB/312MB 83%]
10:32:15.929 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [204MB/312MB 65%]
10:32:16.947 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [205MB/312MB 65%]
10:32:18.054 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [153MB/312MB 49%]
10:32:19.077 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [153MB/312MB 49%]
10:32:19.745 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [166MB/312MB 53%]
10:33:21.862 INFO i.g.d.s.t.FrequencyErrorCorrectionManager - Auto-Correcting Tuner PPM to [0.5] [246MB/375MB 65%]
10:33:45.589 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [242MB/375MB 64%]
10:33:52.935 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [245MB/375MB 65%]
10:33:53.793 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [232MB/375MB 61%]
10:33:54.822 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [233MB/375MB 62%]
10:33:55.919 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [294MB/375MB 78%]
10:33:56.929 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [295MB/375MB 78%]
10:33:58.043 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [193MB/375MB 51%]
10:33:59.057 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [193MB/375MB 51%]
10:34:34.116 INFO i.g.d.m.d.p.P25TrafficChannelManager - Stopping traffic channel: Suffolk County (Project 25)_Site 4_TRAFFIC_29 [206MB/375MB 55%]
10:34:34.119 INFO i.g.d.m.d.p.P25TrafficChannelManager - Stopping traffic channel: Suffolk County (Project 25)_Site 4_TRAFFIC_27 [210MB/375MB 56%]
10:34:34.143 INFO i.g.d.m.d.p.P25TrafficChannelManager - Stopping traffic channel: Suffolk County (Project 25)_Site 4_TRAFFIC_30 [243MB/375MB 64%]
10:34:34.162 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [245MB/375MB 65%]
10:34:39.825 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [247MB/375MB 66%]
10:34:40.683 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [260MB/375MB 69%]
10:34:41.704 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [260MB/375MB 69%]
10:34:42.809 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [206MB/375MB 55%]
10:34:43.822 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [207MB/375MB 55%]
10:34:44.934 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [320MB/375MB 85%]
10:34:45.963 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [320MB/375MB 85%]
10:35:23.360 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [321MB/375MB 85%]
10:35:26.529 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [327MB/375MB 87%]
10:35:26.937 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [298MB/375MB 79%]
10:35:27.952 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [299MB/375MB 79%]
10:35:28.537 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [154MB/375MB 41%]
10:35:29.599 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [155MB/375MB 41%]
10:35:30.141 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [184MB/375MB 49%]
10:35:31.208 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [185MB/375MB 49%]
10:41:58.708 INFO i.g.d.a.c.m.AmbeAudioModule - AMBE CODEC successfully loaded - P25-2/DMR/NXDN audio will be available [451MB/525MB 86%]
msingewald
Norwalk, CT
I have this happening one one marginal PC as well. I am going to try tonight with another PC that has more memory and CPU.
dave3825
Suffolk County NY
So to update on this, I restarted sdrtrunk 5 hours ago and hit mute as my son was doing school. I just hit unmute and its playing audio. So it seems that what ever causes this only presents itself when audio is on. Then it dies after 3 hours.
dave3825
Suffolk County NY
Left it muted for the last 9 hours and just unmuted and no audio. 1300 on ram and 11 percent cpu. Hope someone finds a solution soon. Thankfully I have Trunking Recorder importing and do not miss anything.
msingewald
Norwalk, CT
I ran on a more substantial system, and when I came in today I see that it locked up at about the 12 hour mark. Maybe I need to run Linux!
dave3825
Suffolk County NY
Also in addition to the audio dropping, noticing alpha tags displaying in the line for the control channel and also tags staying on either the left or right speaker after the call has ended.
jjbllitz
Baltimore, Ohio
Sorry that you guys are having issues. I love the software. I run the app 24-7 for days to weeks at a time and have not experienced any overall audio loss and only one lockup I can remember. I mute at night, but leave it running because I'm feeding Calls and an audio feed. My computer is an older i7 running 16GB of memory running latest Win10 home, so pretty beefy. I had more issues early on with tracking the control channel and dropping audio on individual traffic calls. That got better when I switched to a powered USB3 hub (I run two rtl-sdr.com dongles) and got my antenna feed sorted out.
This error concerns me a bit. You mentioned you are running an Airspy, which requires larger bandwidth. Maybe you need to switch to a USB3 port??? Just a thought.
I see this same behavior from time-to-time, especially on the left and right audio channels, but doesn't seem to cause any issue.
dave3825
Suffolk County NY
I am going to try a powered hub but when I lose audio, its just gone. I am not missing it on a call or two, it just stops. Time to search amazon for a hub.
Indianabrad
Jasper County, IN.
Dave, did you get a powered hub yet?
I am running 3x Nooelec Smart v4 on a non-powered USB 3 hub plugged into a USB 3.1 port on a 16 thread Ryzen w/ 32 gigs of ram and my audio stops after several hours also. I did just now up the ram on the JVM to 4 gigs (with the info in this thread) and the audio does seem clearer now. I'm interested to know if a powered hub helps. I am guessing that the audio stopping prob is a major bug that will be worked out for the next build revision.
dave3825
Suffolk County NY
I have not got a powered hub yet. Audio still drops after a while but what I did as a band aide was mute Sdrtrunk, and have trunking recorder import everything of interest and play it thru the browser.
What is interesting is I can run Sdrtrunk for a week on mute, and after a week, untick the mute and it plays audio. But if audio is on from the start, I get maybe a day of audio until it quits. Also, when it will not play audio, it still records perfectly fine.
Indianabrad
Jasper County, IN.
lower your tuner sample rate to 2.048 MHz
My 3 Nooelec's go up to 2.8 MHz & the last thing I'm gonna do is turn them down. Even if I have to get a powered hub for it to keep up w/ the data, I have my non-powered 3.0 hub plugged into a 3.1 port already.
Indianabrad
Jasper County, IN.
Are your audio drivers up to date?
Audio drivers are NOT even the most remote reason (in the entire universe) why the sound drops out after a few hours on SDRtrunk HAHAHAHAHAH b/c all other audio plays perfectly. I will bet my money that the reason is b/c SDRtrunk is in version 0.6.0 Alpha, which is barely halfway to version 1.
LOLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL @ Chris
