ProScan: Lost all my programs
XPS720
Windham County, Connecticut
My PC had to be replaced by a new one and I lost the Sentinel program and it was a long time a go. Just how and where does it get down loaded. I use a BCD536HP and A SDS200. I will need to get ProScann also for each scanner.
XPS720
RandyKuff
Lorain, Ohio
Is this what you have...
That plugs into the scanner not the PC...
R.624641c31da687d6a8d930012a74861f
XPS720
I don't believe it as I found a old flash drive and found Proscan 536HP not Proscan SDS200 Folders, it look like sds200 was not purchased yet. You know I need to ask, If I copy and paste the folders will the radio work on Pro and what is needed to do?
XPS720
I hope this helps as I noticed that when I launch Proscan I see a BCD996 and as far as buttons goes. At the top I only see Option-View=Support. I don't see a port set up anywhere. I should be able to view my 536 on this-yes?
RandyKuff
Lorain, Ohio
Thats posted to show you where to select your 536... From the pull down in the first pic
That is my 200 settings... You need to set YOUR 536 up the same way... In the second pict...
Try clickung Auto Detect... And see if it can find your 536...
XPS720
I know the set up as I had the program for many years. What I am trying to see when my 200 is plugged into my PC Bye USB Wire I dont see Comm Port at the top of my down load.
RandyKuff
Lorain, Ohio
Thats kind of a waste using the USB connection with the 200...
The 200 using the eithernet connection on the front of the scanner connected to your home network is the way to go...
If using USB from the Scanner to the computer, Your going to have to install Unidens Com port driver...
