ProScan: Lost all my programs
XPS720
Windham County, Connecticut
My PC had to be replaced by a new one and I lost the Sentinel program and it was a long time a go. Just how and where does it get down loaded. I use a BCD536HP and A SDS200. I will need to get ProScann also for each scanner.
RandyKuff
Lorain, Ohio
a417
What's this net frame 2.0? I only see 6.0 7.0 at that site. I now see 4 files on that 365 what do use?
as 2.0 is clearly less than 6.0 or 7.0, that would indicate it's an older revision.
windows key + r --> "optional features" --> first option should get you where you need to go.
ProScan
Software Provider
Ontario, Calif.
I have that 7.0 installed now what?
Sentinel doesn't use 7.0. All .NET framework versions are designed to coexist. A later version of .NET doesn't replace an earlier version.
See this post and you should be good to go.
ProScan
Software Provider
Ontario, Calif.
Sorry 1 more thing. How does this Scan Lan Player work? Do I need to keep scanners on open or ready for writing?
What is "Scanner Lan Player"? Can you post a link? Nevermind. That's mine. It's been a long day.
What type of scanner are you using I see you're using a 536 and 200 from another post
Did you setup the LAN settings in the scanner?
{edit}
You need the scanner/s on and not in Mass Storage mode.
{edit again"
What are the IP addresses of the 536 and 200?
ProScan
Software Provider
Ontario, Calif.
XPS720
There has to be an easy way to get my scanner on my Proscann. In was told to plug in WIFI--it don't light up, I searched for latest drive called stm32102 and still no light as I plug it in. I have 2 scanners and I honor the 2 with proscan I like to see them on my 27" monitor. Because of a computer loss and new one all I ask is"Easy way for an old man!
73's
ProScan
Software Provider
Ontario, Calif.
73's
No driver is needed. Did you see the link in post #15 on how to setup the 536 Wi-Fi? Does the scanner show an IP address. Go to the menu Wi-Fi Setup -> Show Wi-Fi Information
What do you mean by "it don't light up"? If refereeing to the 200. I would setup the 536 and get that working before moving on to the 200.
{edit}
Since you're using ProScan, you can use ProScan to access the 536 and 200 RTSP Ethernet audio instead of the Scanner LAN Player but it's your choice. As you may know, each instance of ProScan needs to be in separate folders.
RandyKuff
Lorain, Ohio
{edit}
Think he means his WiFi adapter is not powering up...
He's probably not supplying power to it from the scanner or other means...
XPS720
When I plug the WIFI into 386 there is a green light that should light up, it did on my PC. Separate folders, I know, as I had 2 Pro on my old PC. Not sure about Ethernet audio, sorry. I know when I did long a go it was so easy and nice to see the front of scanner on the programs. Sorry for trouble.
ProScan
Software Provider
Ontario, Calif.
Your router has Wi-Fi. Is that correct? If so then you don't need to setup Wi-Fi on your computer. See the link in post #15
