Low profile VHF antenna
AK9R
Central Indiana
Anybody have a suggestion for a low-profile VHF antenna. I'm talking about the small antennas that are only 2-4 inches tall. Are any of them any better than the others? I will be using it on a fixed frequency, so wide bandwidth is not required. NMO mount would be a plus.
Thanks.
Mile High, or more.
I know one person who tried it. It was used primarily on 1 fire channel, and a couple of others within 4mhz.
To quote him, "It sucked". He went back to the 18 inch whip. Apparently the type works well in the 450 and above range.
FFPM571
Nashvillle
The Phantom Elite in VHF looks like a half football. It is OK at best.I have one department that uses them only because they keep damaging a roof mounted 1/4 on their Explorers on a low garage door. But nothing beats a 1/4 wave. The UHF Phantom Elite looks like a small shark fin. I use one and have no issues in UHF
methusaleh
New England
I concur. Super narrow tuning on the VHF low-pro antennas, we are talking 2MHz if you are lucky. 4MHz would be generous.
UHF are much more forgiving, I have even seen some with claims of gain. I guess they could fit a decent sized 1/2 wave or so piece of wire in there.
OP says single frequency, so narrow bandwidth shouldn't be an issue unless it's a repeater with really w-i-d-e offset.
I'd concur, everyone I know that has tried one has given up and gone back to quarter wave. If you really want one of these, go name brand.
Most of these won't run high power, usually 50 watts are less.
AK9R
Central Indiana
It'll be on a simplex frequency at less than 50 watts.
I looked at the installation instructions for the Laird Phantom Elite on VHF. Getting the bayonet mount lined up properly with the vehicle looks like it could be a little fiddly.
The few I've looked at used a standard 3/4 inch hole. You needed access to the underside to tighten down the nut.
Bonus is you can always swap it out with an NMO mount.
Or, just go with one of the antennas that uses the NMO mounts.
I've never installed one. I've talked to a few guys that have used them and asked for feedback. None of it was good, so they couldn't really provide any recommendations.
I've used them on 800MHz and they work fine. Comparable to a 1/4 wave.
KevinC
Encryption
I'm everywhere Focker!
My only experience with these in VHF-Hi was when they were in their infancy, so it may not be relevant.
An ISD "had" to have these on their fleet of buses, long story short, they were swapped for 1/4 wave whips within a few weeks.
Surprisingly the low profiles I've done for VHF-Lo worked quite well, once you got them out in the open so you could tune them. But they take up a lot of real estate.
AK9R
Central Indiana
Check the installation instructions for the Laird Phantom Elite VHF. You replace the standard NMO nut with a special nut that has the bayonet mount for the antenna. The slots on the bayonet nut have to lined up with the vehicle so that when you attach the antenna, it lines up with the vehicle. Not impossible to do--just would seem to take a little more time to install compared to a conventional NMO mount. And, because of the special nut, swapping back and forth between the Phantom Elite and a conventional whip is a little more difficult.
I hate banging a 1/4 whip on the bottom of the garage door every time, but that may be the best answer. Besides, what could be more intimidating on the highway than a black Chevy Tahoe or Ford Expedition with a whip antenna and a lo-pro 800 MHz antenna on the roof? "Do you really want to pass me? Really?" ;)
prcguy
I have a couple of Laird/Antenex TRABT1420 VHF low profile antennas and they simply screw onto a standard NMO mount and the frequency adjustment is easy access on the side. The performance is way down from a full size 1/4 wave and the BW is really narrow, about 1MHz at best.
I can loan one to the OP for testing if he pays shipping and I have versions that cover 142 to 160MHz and 150 to 168MHz.
prcguy
ramal121
Lots and lots of watts
Calif Whine Country
As with all antennas of this type you'll need a good ground plane, more than you'd expect, to tune properly and get the reflected power to a decent level.
I'm dealing right now with a Sinclair VHF transit antenna, kinda the same thing. Mfg states MINIMUM 48"X48" ground plane.
12dbsinad
Look at a Stico flexible antenna. I run this on my pickup as I have low overhead door. You can bend the thing all the way flat without damage and even tie it in a knot
STI-Co | Antenna Manufacturer | Antenna Systems | Antenna Accessories
FFPM571
Nashvillle
even the oil filter style can VHF are horrible even tuned. The Bayonet base for the Elite is not hard to do its just needs to be lined up its actually easy. The sti-co flexi whip is nice and works great though its 2X the price of a regular 1/4 wire whip
AK9R
Central Indiana
I forgot about Sti-Co. Thanks for the reminder.
I'll give a regular 1/4 whip a shot and see how it works out.
My pickup doesn't fit in the garage, so not an issue for me. My wife's car is a Ford Escape, and it's got a 1/4 wave VHF on the top. It hits the garage door. No where near as tall as a suburban, but still, it hits. After doing this for 5 years, I've seen no issues at all with the antenna or the mount. Maybe a slight mark on the inside of the garage door where it hits, but that's it.
I did briefly consider one of these low profile antennas for hers, but everyone (and I mean -everyone-) I talked to who had tried them had referred to it as a "waste of money", and each and every one of them had taken the antenna off and replaced it with a quarter wave. I was offered a few of these old antennas because no one felt they were worth anything more than the trash can.
Most people won't even notice a 1/4 wave whip on top of a vehicle at highway speeds. Personally, I think the 1/4 wave antennas are "lower profile" than the soup can sitting on top of the vehicle.
If image is really a concern, get one of the Stico boxes that allow you to use the AM/FM radio antenna. We've got one of those on the chief's car and it works well enough.
Other option would be something like a Panorama Antenna "shark fin" with the VHF whip. Looks like a modern AM/FM Satellite radio antenna. They'll provide a port for cell, 2.4GHz, GPS and a stud that permits installing a whip of your choice. Not cheap, but it would likely blend it better than anything else (other than the Stico).
FFPM571
Nashvillle
Sti-co factory style OEM antennas do not use the factory antenna. They use a custom modified OEM with the matching coupler box. We remove the factory one and return it with the car so when its changed over it can be put back to normal. They also start at $300+ depending on the vehicle
12dbsinad
I was looking at one of these for the wife's vehicle. It looked pretty neat except when I found out the price! I hope the performance is good!
FFPM571
Nashvillle
the performance of the sti-co is very good. It is used in undercover vehicles by most of the .Gov agencies
