LRRP
LA6FRA
Stavanger. Norway
Hi. Anyone how can help me with LRRP? Do you know if it is possible to show in the only the data received, for example, the last five minutes? I am not interested to see all hundreds older data location.
racingfan360
DSD+ logs the data to a file called DSDPlus.LRRP each entry has a timestamp. You could edit the file and remove old entries, or delete/move/rename the file every x minutes.
Fredo68
Type ? on the map and the list of commands will be revealed. You'll find a solution there, I'm sure.
LA6FRA
Stavanger. Norway
Thank you for the information. I would like to find the way to do it automatically, some script deleting the entries every X minutes.
Fredo68
That would be the max age setting? Do you want to only display the last X minutes of data or is your goal a method to delete the contents of DSDPlus.LRRP at intervals?
Fredo68
I've also monitored LRRP via Tetra/TTT - I didn't see much difference...but I wasn't really looking
LimaZulu
....some script deleting the entries every X minutes.
This is easily doable but such thing could lead to undefined behaviour. Ether the file would not be edited because of another program using it or it could be corrupted. No one can really tell which and when one of the above will happen. It will work for the majority of the time but it will be loaded gun waiting to shoot you in the foot.
Fredo68
If anyone wants to have a go with LRRP/TTT have a look at sdr://88.24.79.29:5555 in SDR#. Go to channel 3628 for a near constant stream of LRRP traffic.
dave3825
Suffolk County NY
I took a quick look and did not see any sdr://88.24.xx.xx:5555 servers.
Fredo68
It's now disappeared as you've all seen. It appeared to be a bus system in the Canary Islands. I did record a few minutes IQ if anyone's interested
IU0LFT
Italy
Question, I'm using LRRP with DSD-Fastlane to monitor DMR Network, it's working well, but any chance to have alias name instead DMR ID?
Regards
Giuseppe
