LTR trunked repeater on GMRS?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
So the whole point of this single channel LTR is to limit access to a GMRS repeater? Wouldn't it be much easier to use a controller or internet controlled AC power switch to just shut the repeater off if some unauthorized fools get on?
I’m all for playing around, but the OP’s reasoning does seem like a lot of work for little reward. It gives zero privacy and if someone wants to interfere they can still just key up on the input while your talking and wreak havoc.
Pr999
Allegan County, Michigan
That's not the point at all.
What I'm doing is to experience and learn how to operate and maintain a trunking system. I've never used one or owned one, so this is a small project for me. It may not be a full multi-channel system, but I'm using the resources I have and can get atm. I currently hold a GMRS license, and LTR is the only legal option. It will remain a private repeater for just me and my family; it won't always be on unless needed. But this is just an experiment, so I can play around with trunking.
Project25_MASTR
Millennial Graying OBT Guy
Texas
LTR even on a single channel provides some pretty nice little functions. For one, talkgroups and all call groups come into play. Yes you could do it with a community repeater controller or a repeater that supports multiple tones but on the subscriber end you would be forced to scan in a not always convient way. You also gain the whole access control capability with not a single consumer grade GMRS radio being able to use the repeater. User ID information is standardized across vendors. Seriously, does anyone else have a mix of Motorola radios that do MDC1200 and Kenwood radios that do FleetSync with the only common ground for ID being a digital protocol or is it just me who runs into this issue which is why I abandoned analog for personal radios? Motorola and Kenwood (and I assume Icom) made multiple radios that could support LTR and were type accepted for Part 95.
It's not a bad starting point IMO.
12dbsinad
LTR on a single analog channel sounds like a complete disaster unless it's just 1 talkgroup without multiple users and is strictly used for access control. There is no way to monitor the channel like CTCSS/DCS, which I believe is a requirement for GMRS. LTR is useless for a single channel IMHO.
cavmedic
Pottstown Pa
Using a LTR controller on a single repeater on GMRS is a great way to eliminate the idiots who do idiot things on repeaters. Listening to them scratch their heads trying to figure out why they cant scan for the PL on their chinese garbage radios to access the repeater is fantastic.
cavmedic
Pottstown Pa
We had several Trident LTR Controllers in the early 90's I just looked and several are on ebay $40 to $100 range
I think the shop just tossed two or three of them that were in the back room collecting dust. Being a part timer now, I don’t get first dibs on dumpster interception anymore.
I still know where two more are racked with some GM300’s as RX,TX that I moved to the side to make room for the NXDN trunking racks that took their spot.
I may make an inquiry to see if they want me to dispose of them so they don’t have to and play around again with this. I have a few CDM’s that were on that system back in the 2000’s , and still have the programming to match the controller settings 😈
Pr999
Does anyone know where to even get programming software for those Trident LTR controllers?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
It's the only experience I can get my hands on atm. It still would be cool to play with regardless, and it's also still a leeway into what trunking is like.
Of course. The repeater will be very low power throughout its testing phase, and it will only be on periodically. I just plan on it being a personal repeater to use around the city, but if I think it can see more usage. I might open it up (with or without LTR) unless you guys have any other ideas.
100%
If you can get a LTR controller, get it programmed and interfaced to a repeater, go for it.
You will learn. It will increase your skills and knowledge. Have fun with it.
It will keep the CCR's out.
jeepsandradios
East of the Mississippi
99% of the programming wa done with a terminal emulation software. We used procom orginally but now I use Putty or SecureCRT. Still have 3 tridents in use for conventional stuff. If local you need a NULL modem on your serial port. Ints menu driven and the manual has the steps.
