SteveC0625
Order of the Golden Dino since 1972
I just picked up an M1225 model number M44DGC90J2AA. All the reference info I can find or already have here say it is a 20-24 channel, 25-40 watts, 450-474 MHz conventional UHF transceiver.
When I fire it up, the name of some excavating company scrolls across the screen and then it settles on LTRSIT1. None of the buttons do anything except give an error beep. It won't change channel or scan.
I have the latest version of the Radius 1225 software HVN9054 version 4.0. When I read the radio the first time, it came up as a 20 channel radio with all 20 modes programmed the same. I redid the code plug with 8 conventional channels with nothing special except scan. It writes to the radio properly, and if I read the radio again, it reads back the code plug that I wrote. However, it still behaves like an LTR radio and none of the buttons do anything.
I don't find anywhere in the code plug a place to change or delete the name either.
I'd almost think it's an LS model in conventional clothing or it's got an option board in it that needs to be removed.
Anyone ever come across anything like this before? Any help gratefully accepted!
