macom m7100 pinout 37 pin help
riccom
Kansas City, Missouri
i went to the io boards, not alot of help, i have a 37 pin dash mount radio, and i need what pin will put the radio in to programming mode.
the issue is i see alot of pinouts for 25 and ect.
not a solid one for the 37 pin, any help would be awesome!
merlin
DN32su
The radio goes into program mode attatching the DB15 programming cable. Remote mount with programming port.
You will need to buy or make a CA101288V5 programming cable.
the screenshot at the right shows the 37 pin pinout. Tie ignitin sense (10) to a+, that will set programming mode.
A remote mount on the bench, you need the power cable connected and the A+ (yellow) from the programming cable.
(with or without a head.)
