Being the one currently in charge of radios for my FD, I'm getting complaints from some members that the volume control for one of our first-out units is causing a problem.
Reportedly the audio levels are changing on their own, and there is a notable lag/overrun in the intended volume control changes.
I have not been able to find any bad connections to the speaker, nor getting any random volume changes when I am in the vehicle. (I took it out on about a 30 minute test ride a couple days ago, monitoring the local NWS broadcast while hitting bumps and randomly altering the vehicle's movements.)
Has anyone else run into this problem? If so, would you mind sharing what you found to be the problem and/or resolution?
