MARCS Tone Outs for Brown County- Unication G4 pager
engine183
Mount Orab, Ohio
Good Evening,
I hope this is in the correct forum/thread.
I’m seeking information about the tone frequencies, timing & programming for the MARCS tone outs for Brown County, Ohio. Specificity Mt. Orab Fire & EMS. I was provided with the tone-out frequencies (numbers) for Mt. Orab Fire/EMS. 10 & 18 for the 2-tone Fire Dispatch and 18 (long tone) for the EMS dispatch.
I’m new to programming/using a Unication G4 pager and the PPS software. I’m using the newer version of PPS (V0.4.0.30) and I’m not able to find many “help” videos/information on this specific topic of programming tone-out on a P25 system. My goal is stand-by alert mode (silent) until the department is toned-out. I have tried several different combinations of programming my TG (8501) with a Subgroup (E-2) and using the Tone Alert Feature (E-7) without success. I'm sure that I have missed a step or not set something correctly.
Can anyone either provide some direction on this programming or a public source that a novice would find helpful using this newer version of PPS?
Thanks for your help & understanding.
n3obl
Ø
PA
Sounds like someone gave you console codes instead of the actual tone frequency. Two tone paging would be for example 561.1 / 1122.5
That’s what you need for it to work.
wa8pyr
Lead Database Admin
Ohio
Actually those might be the Unication tone numbers. Tone 10 is 546.9 to 578.1 hz, and tone 18 is 796.9 to 828.1 hz.
My guess is that the tone frequencies he actually needs are 553.9 and 810.2 hz.
Update: HA, I WAS RIGHT! Per the Brown County Wiki page (amazing what you can find if you actually look for it), Mt Orab's tones are 553.9/810.2 (probably 1 second/3 second) for fire, and 810.2 (probably 8 second) for EMS.
To the OP - you need to set those up as two separate alerts in your sub-group list.
engine183
Mount Orab, Ohio
Is it safe to assume that the tone frequencies are the same for VHF (154.190) and the MARCS P25 system? I'm trying the EMS tone now without any luck. Maybe I'm doing the programming wrong. Is there a good "go-by" or instruction for setting up tone-out on trunking P25 systems? Any help (or link) would be appreciated.
wa8pyr
Lead Database Admin
Ohio
If they sound the same on P25 and VHF they probably are. However, if the tones aren't perfectly clean on P25 it won't work there and you'll be limited to VHF.
Configuring QC2 on Unication:
If you're using the newest PPS these instructions might be a tad off, but it's close enough.
