MCS2000 Programming
billy5715
Boston, MA
Trying to program one of my MCS2000's I am using an aftermarket RIB and cable. I am almost 100% sure that is where my problem is lying. I used to have a Motrola RIB and the correct Moto Cable but I have moved numerous times over the past few years and can't find them.
Everytime I hook up to the radio it will go into "programming" mode and the computer will start to work, then the CPS will tell you that the radio had a communication failure.
CPS V. R02.02.00
Any tips or suggestions that anyone may have will be greatly appreciated.
Thanks, happy holidays!
jim202
New Orleans region
The MCS2000 radios are very sensitive to low voltage while programming. I have tried several
different RIB units. The Polaris is one that will not work with this radio. It's voltage is too low
to get the computer to talk with the radio. Blame it on Motorola.
Jim
CPS V. R02.02.00
billy5715
Boston, MA
Does anyone know of any aftermarket RIB's that will work with the MCS2000? I have searched again for my OEM Motorola RIB and still can't find it.
If anyone knows of a brand that has worked for them please let me know.
This aftermarket one I purchased does have a AC Adapter plug-in, will it work better with the AC Adapter or no?
Thanks.:confused:
b7spectra
EMS Dispatcher
Cobb County, GA
I've used the Polaris II RIB and it works just fine on MTX/MTS/MCS/Saber/Spectra/HT600/HT1000/MT1000/Maxtrac/GM300/Radius and lots more that I've lost count on. I just keep a full charge on it before going to the field. On my desk, I will have it plugged into the power supply while programming.
ramal121
Lots and lots of watts
Calif Whine Country
My motorola RIB works great when the 9volt battery is fresh fresh. But as soon as it falls off, I start getting more and more errors. Wenched a fix by using a 8 cell AA battery holder (12 volts) and securing outside the RIB. Fugly but works. Beats 9volt battery by at least 10 times.
Anybody try to juice up the voltage to a Polaris to see if that helps? Although that may be dicey with the internal rechargeable battery.
firemanbj515
Tn
mcs2000
I need some help. Please
I bought a Motorola mcs2000 vhf 100 watt radio.
I am wanting to prog this radio we have the software its the older software it runs off a old computer and someone told me for some of the mcs2000 you have to have the new software? So how do I know if the old software will prog my radio or do I need the new software. And also they said they are very hard to prog you will burn it up. If not careful with the prog.
Thank you for your time
All help would be greatly appreciated
