MD-380 Programming Question
Meestor_X
So I just picked up a pair of TYT MD-380 radios.
ATM I'm only interested in Analog usage, so please don't refer to any digital channel programming.
I have set up 5 analog channels which work properly.
I want Channel 1 to be an "ALL CALL" channel which I created using the scan feature. When any radios are being used on channels 2-5, if someone transmits on channel 1, all radios switch to that channel and receive the call. Took a while to figure out how to do all that, but since it's my first time with these radios, I expected that. The scanning setup is working fine.
Something odd happens however.
When any radio transmits on channel 1, there is no delay AT ALL between when PTT is pressed and the user can speak. That is to say, when on channel 1, the transmitting person can press PTT and speak immediately and no words are cut off.
However, if two radios are on any other channel (channels 2-5) and PTT is pressed, there is a delay before audio is transmitted on the initial PTT press. The squelch on the receiving radio opens immediately when PTT is pressed, but the mic is not "hot" for about 1 second on the initial press of PTT. If PTT is released and quickly pushed again, there is no delay on the 2nd and subsequent transmissions.
Is there a setting in CPS I can change to get rid of the delay between the initial PTT and the receiver receiving audio when a channel has autoscan enabled?
Firmware version is D013.034
Follow up question - are there any detailed explanations for each setting in CPS for a newbie like me?
jonwienke
More Info Coming Soon!
VA
NO. ALL CALL is a digital-only feature. The radio is scanning multiple analog channels and that is why you get the delay. The radio pauses scanning once it receives a transmission, so that is why follow-up calls don't have a delay. If you programmed the channels digital, you wouldn't lose the first second or two of the transmission--the radio is on a single frequency and is simply behaving differently depending on talkgroup ID.
It's totally pointless to get DMR radios and then use them analog only. If you aren't going to use digital, you'd be better off getting some Baofengs.Take the time to learn how to program the digital features, and you won't have these problems.
Meestor_X
Thank you for your reply.
I understand the differences between analog and digital. I've been doing digital with other digital-only radios for many years and may again in certain situations. Please don't make this thread into an analog vs digital debate.
So, again, my question is about the analog mode on the MD-380 and only that. What doesn't make sense is that when a radio is on channel 2 (not part of the scan list) and a call comes in from channel 1 (which is the only channel on the scan list) there is no delay in the audio, but there IS a delay (on the first PTT) when using channel 2.
Additionally, no matter what channel I transmit from, the squelch opens immediately on PTT, but the audio is still muted for a short period on the first PTT.
Does not seem right. It sounds like you may not know why this is or what to do about it, but perhaps someone else has some insight into the analog functioning of this radio?
jonwienke
VA
It is because the radio is scanning multiple frequencies in analog mode (which it doesn't do particularly fast, about 5 channels per second), vs. comparing talkgroup IDs to a programmed list (which it can do in a millisecond or two). After the first transmission, the radio temporarily stops scanning, so reply calls don't have any perceptible delay. But you're never going to get instant squelch open on the first transmission, unless you get lucky and key up just as the radio switches to that frequency in the scanlist.
You're basically trying to use a bananna to pound screws into a concrete block by using analog scanning instead of digital talkgroups for all call. If a properly-functioning all-call function is important to you, you need to use digital--it's the correct tool for the job. Trying to replicate the functionality in analog is always going to be a poorly-functioning kludge with significant limitations.
Meestor_X
That's the thing, though, I don't think you're hearing me. I DO get instant squelch open, on the current channel as well as Channel 1.
What I don't get is instant AUDIO on the current channel ONLY.
I'll say it again.
Radio A is on channel 2 and Radio B is on channel 2. Press PTT on Radio A, the squelch opens IMMEDIATELY on Radio B, but the audio is muted for about a second.
Radio A is on channel 1 and Radio B is on channel 2. Press PTT on Radio A, the squelch opens immediately on Radio B AND the audio is not muted at all (no delay with the audio)
If it were a scanning issue, then there should be a delay opening the squelch, which there isn't. Also the audio mute would be delayed on either channel, no JUST the current channel, correct?
I understand. If you don't want to talk about analog, then I respectfully ask you to move on. As I keep saying, I'm not interested how to do this in digital mode, I know full well how it is accomplished using digital.
jonwienke
VA
Have fun. In my opinion you are wasting your time. Analog is not designed to do what you're trying to make it do.
