seandeely
French Lick
I'm using DTMF signaling on CP200XLS radios and am wanting to remove MDC and Quik-call II from the selective call list. We have crew leaning radios on walls or obstacles while on their belt and signaling MDC and Quik call so I want both disabled. When I go in to CPS I have not found a way to disble or remove those systems from the selective call list, and when I try to delete them it brings up the warning "unable to delete minimum of 1 is required". Any advice to help?
Magnetsteve
Central Arkansas
I am confused as to what you're needing exactly. You can only assign one signaling system per conventional personality on TX. If it is set up for DTMF, how are they sending a MDC or QCII signal?
