New to cps..
MIKEYP0323
Hi all, i recently came across a copy of cps for my ht1250 and i have some questions. It seems that i have figured out the basics. What i dont understand is the quik call and mdc stuff. How does it work? And whatis it for? How could it be utilized in a small ambulance service? My other question is pertaining to emergency mode, how do i program the radio so that when the emergency button is deppresed all of the other radios will display the identifier and sound an alert tone????
Luis_R
Quick call is used for decoding pages. You can program the type of alert you want and the tones you want to be used to open up the radio upon Rxing those tones. Not gonna ramble on go here - MDC1200 - The RadioReference Wiki
Should get all your answers there.
bezking
On the Road
Quick Call II Tones are what cause Minitor pagers to activate.
MDC-1200 is a signaling format. When used correctly, a radio user will be able to see who is transmitting on the radio's display, amongst other things as outlined in the wiki article above.
MIKEYP0323
thanks guys... what is the difference between sel cal and alert ... what is an mdc message??
bezking
On the Road
Sel Call = Communication that only the other party will hear.
Call Alert = Causes the other party's radio to play a tone, vibrate, etc.
MDC Message (basically same as MDC Status) = Short, preprogrammed TXT message such as "IN SVC," "AT STATION," "AT LUNCH," etc. I don't believe the 1250 is capable of MDC message.
MIKEYP0323
many thanks.... that was what i was looking for.... now for the programming of the emergency button???
bezking
On the Road
MDC1200 offers the Emergency feature, which transmits a data burst signifying there is an emergency. This is typically programmed to the orange button on the top of the radio. A short press would start the emergency transmission, and a long press should turn it off. A dispatcher, with a compatible console or radio, will see that there is an emergency and will see the ID of the radio that transmitted it. They will then "acknowledge" it, and the radio will show that the dispatcher saw it and the radio will stop transmitting the MDC signal. Optionally, a loud tone can be emitted by the sending radio as well and the radio can also automatically start transmitting audio for a certain number of seconds.
Note that some radios are able to see the ID of the emergency, but the 1250 can not. A dispatch console or different radio would be required.
Another interesting feature is Stun, where a dispatcher with a compatible radio can remotely disable a lost or stolen radio so it can not be used to interfere with the system.
MIKEYP0323
once again thanks.... so i guess the thought of having other radios in my system emit a loud beep or tone then showing the identifier is out of the question... i didn't see the stun feature in my cps??
bezking
On the Road
It's kinda weird. Stun Receive is enabled automatically when Sel Call/Call Alert is enabled. To TX a stun to actually kill a radio, you need either a different radio or a dispatch console.
Luis_R
No, not really. Use MDC and PTT id in a pre or post burst fashion in conjunction with emergency. Will give you what you're looking for. As long as the radios are able to encode PTT id. As far as stun feature your radio may not have that feature available, may be a model specific feature.
