MedFlight TGs
jsoergel
Cincinnati/Dayton, OH
I've been monitoring MedFlight for the past two weeks to get all the RIDs (see below) and have noticed a few changes:
1. It sounds like Tac 1 (17522) and Tac 2 (17525) are now Ground 1 and Ground 2. I have heard both in use but don't know exactly how they're chosen.
2. The MICU talkgroup (17520) doesn't appear to be in use. I think the MICU personnel are all on Ground 1/Ground 2 as "Team #."
3. MedFlight 21-29 callsigns are on Heli 1 almost daily. I think these are the "Fly Cars" which supplement each base.
RIDs:
2490131 MedFlight 9 (N130JV)
2590175 Monarch 1 (N145NC)
2590394 MedFlight 5 (N130CL)
2590543 MedComm
2590544 MedComm
2590549 MedComm
2590559 MedComm
2590560 MedComm
2590568 MedComm
2590569 MedFlight 3 (N130KH)
2590586 MedFlight # (N130NE) - spare for N130NW*
2590587 MedFlight 6 (N130MU)
2590588 MedFlight # (N130BU) - spare for N130HB*
2590589 MedFlight 8 (N130NB)
2590594 MedFlight 4 (N130EE)
2590617 MedFlight 21
2590618 MedFlight 22
2590619 MedFlight 23
2590620 MedFlight 24
2590621 MedFlight 25
2590622 MedFlight 26?
2590628 MedFlight 28
2590629 MedFlight 27
2590631 ?
2590634 ?
2590635 ?
2590642 ?
2590643 MedFlight 7 (N425AM) - loaner for N130KR*
2590988 Team 1
2590989 Team 3
2590990 Team 4
2590991 ALS?
2590992 Team 6
2590993 Team 3
2591041 Team 5
*N130HB, N130KR, and N130NW are all out for maintenance at the moment.
rcid1971
I have 2590588 using the call sign "MedFlight 4" on 11/03/2020 and 11/10/2020.
IStebleton
I have 2590643 as 130KR. It was using that ID early in the summer
wa8pyr
Lead Database Admin
Ohio
Something to keep in mind is assigning a "permanent" alias to an ID is potentially problematic. MARCS has a policy whereby a radio is assigned an ID and it keeps that ID throughout it's service life unless it's sold or disposed of. Radios get moved around a lot, and as such, the alias name assigned to it in the Wiki or wherever may not be correct.
In the case of Medflight, a bird that's Medflight 3 one week might turn up as Medflight 6 the next week, if they've had to play monkey move-up for some reason.
jasonk
Dayton, OH
What is the best TG to hear them dispatch crews to scene flights ? Do they use the radio for this - or is it all done by Pager / Phone ?
jsoergel
Exactly. This is why I included the tail numbers, although those can also swap. However, that usually involves removing the radio from the helicopter. N130KR (the normal MF7) is out of service, so they had to borrow N425AM from Air Methods. It's now flying as MF7 and using the radio from N130KR (2590643).
I think it must be done by phone these days. I have not heard them dispatch a single flight, nor have I heard any crew radios (I know they exist, but typically aren't used when the crew is hooked up to the aircraft). That points towards phone being the primary method communication while at their base.
engine183
Mount Orab, Ohio
Cincinnati ( UC Aircare) does most all dispatch & status updates on TG 21006. You can hear they confirm daily pre-flights and weather checks as well. They fly from three different base locations. Also, you can hear other flights inbound/outbound from the Cincinnati/UC Hospital area coordinating with Aircare.
phask
zanesville
They have a satellite-based system in use. It can do voice cams, data, and aircraft diagnostics. There was an article by the company that does their maint. outfits and leases the birds.. (the name alludes me, they are on the Gulf Coast - oil platform work)
jsoergel
Metro Aviation.
jsoergel
And as discussed yesterday:
Monarch 1 is using N995AL while N145NC is out of service. RID is still 2590175.
Also, it appears that MF1 (N130NE) and MF12 (MICU 12) are both using 2590586. The MICU was using it last night and the helicopter used it this morning.
phask
zanesville
Possible Handheld?
jsoergel
Possible Handheld?
Not sure. I know the helicopter radios are connected to the instrument panel plus probably a button on the cyclic, and also interface with the flight team’s helmets in the back. But I don’t know if that could be accomplished with a handheld.
