BCD325P2/BCD996P2: Menu button not working
Ringer2013
OKLAHOMA CITY uk
I need some help with menu button. When I try to enter the menu when pushed it blinks the goes back to scanning, it was working but I must have done something wrong.
Ubbe
Stockholm, Sweden
Some general advice:
If you have a communication port on the scanner then disconnect any cables that goes to your computer.
If you halt scanning by another button, will it stop scan? Then try the menu button.
If you can open up the scanner then look at any cable that goes to the keypad and pull that out and set it back again.
/Ubbe
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Welcome to the forums. Are you certain you're not pressing a FUNCTION button by mistake? As mentioned previously it would help out greatly to know what model Uniden
tvengr
Well Known Member
Baltimore County, MD
Does it say Key Safe Mode when you press the MENU button? If it does, turn the scanner off. While pressing the Scroll Knob, turn the scanner on to exit Key Safe Mode.
tvengr
Well Known Member
You say the scanner blinks when you press the button. It sounds like the button is working. Read my post #7 above.
fxdscon
¯\_(ツ)_/¯
The model type where added just after post #10 where made.
/Ubbe
The scanner model number was posted in the title of the thread at the time the first post was made. See post #11.
