MICCOM DMR Operations
W2SJW
Senior Member
Northwest NJ
I know it's been a couple of months, but I just wanted to update you guys that this system is a 7-site IPSC setup, and we've found 5 of the sites (most are noticed to be at properties owned by St Clare's:
  • Oxford (Warren County)
  • Hackettstown (Warren County)
  • Randolph (Morris County - main site in the system, it appears)
  • Denville (Morris County)
  • Sunrise (Sussex County)
Anyone that can help finding the last 2 would be greatly appreciated. The sites should always be carrying MICCOM on slot #1 & Atlantic on slot #2, and it seems the 5 sites discovered already are sticking to CC8 & CC10, so that should help narrow it down...
NotATechGuy
NotAMember
So it seems that there are two sites (Denville and Dover) who rebroadcast the EMS talkgroups who also repeat hospital operations. You can hear the operator paging floors, security, maintenance etc.. I believe they have a TRBO system tied into their PBX/exchange. The talkgroups are 4000100 and 4000200 always on TS2.
I attached frequencies owned by Prime and my findings for St. Clares EMS. Some results contradict the FCC info in terms of signal strength. I also had a problem with other TRBO systems encroaching in on some of these frequencies from my location. The last 2 frequencies are duplicates but carry data/voice on a different color code.
I'll let you guys decide what to do with it.
Code:
Prime Healthcare Services Saint Clare's LLC, d/b/a Saint Clare's Health System
Freq				Location	Type	Signal Strength		EMS			Offset +/-5	Notes
452.025 - Confirmed CC=8  TS=1	Denville 	Fixed	Fair Signal   	        Confirmed EMS	  	457.025
452.300 - Confirmed CC=8  TS=1	Dover    	Fixed	Fair Signal		Confirmed EMS		457.300
457.025 - Confirmed CC=8  TS=1	Denville 	Mobile	Strong Signal		Confirmed EMS		452.025
464.225 - Confirmed CC=8  TS=1	Randolph 	Fixed	Fair Signal		Confirmed EMS		469.225
461.325 - Confirmed CC=10 TS=2	Dover    	Fixed	Very Strong Signal      Confirmed No EMS	?
461.450 - Confirmed CC=10 TS=2	Randolph 	Fixed	Weak Signal		Confirmed No EMS	466.450
461.325 - Confirmed CC=8 TS=2	Dover		Fixed	?			Confirmed No EMS	?		Hospital Ops
461.400 - Confirmed CC=8 TS=2	Denville	Fixed	?			Confirmed No EMS	?		Hospital Ops
W2SJW
Senior Member
Northwest NJ
I was told about the local in-hospital operations being on the system (that traffic is deliberately designed to not leave the campus coverage area).
I'll see in my travels if I can actually cross-confirm what you found here...
NotATechGuy
NotAMember
I live right between the two systems and my antenna is pretty high up so it might make sense why I'm picking them up. You can probably pick up Dover from parts of the the Rockaway Mall, not sure how far Denville reaches. I checked each frequency twice on that list before writing confirmed. I don't know if the two sites missing are indeed the hospital campus's or a newer tower to extend the system out. I wouldn't be surprised if one is up in Vernon but Sunrise seems to be a strong signal and a prime location.
W2SJW
Senior Member
Northwest NJ
I discounted that one 457 channel, as that's obviously a repeater input. The 464 Randolph channel has me confused, as someone already submitted 463.375 as Randolph a few weeks ago.
That's supposed to be the strongest site in the whole system. The re-use in the hospitals was planned, and the maintenance & ops TG's don't go out over the IP side of the network...
Sybex7254
Florida
I can confirm 464.225 as the main frequency for the Randolph site carrying the ALS traffic. I have it programmed both as a conventional DMR and a DMR One Frequency site and am receiving both AHS and MICCOM on the TG's and Slots in the database.
Not hearing anything on 463.375.
I'll have to take a ride and see if I hear anything on 452.025 in Denville or 452.300 in Dover.
W2SJW
Senior Member
Northwest NJ
Great! I find it hard to get over that way much during work & any other members willing to help narrow down the last sites is a great help!
Sent from my Galaxy S6 via Tapatalk 5
W2SJW
Senior Member
Northwest NJ
OK, I've got the last few updated entered. We seem to be missing 1 more site. Hopefully I can figure out in the next week or so if 452.025 is a campus-only channel or a wide-area one...
W2SJW
Senior Member
Northwest NJ
rr60
This frequency appears to be for the Morris & Warren areas, so anywhere else, YMMV.
463.850 - CC=8
MICCOM St. Clare's - TG 10005000 - TS1
Atlantic EMS - TG 16000000 - TS2
Hackettstown RMC EMS - TG 11002000 - TS2
I hear Atlantic units at Overlook, so I'm not sure if the channel is linked to other repeaters on other frequencies via IP SiteConnect, or if there are numerous sites on that specific frequency.
I have found another frequency in addition to some of the others on this thread. I suspect one is in Middlesex County. I maybe hearing two systems on same freq (different signal strengths). It appears as DSD on the 536. I will run DSD+ tomorrow.
It is using the same CC and TG's as above and sounds like same areas. I suspect it is a Part22 as I did a quick FCC looksee with negative results.
The frequency is 464.225 CC TG and T\S same as noted above by Scott.
W2SJW
Senior Member
Northwest NJ
That is the Randolph site you are hearing - the most powerful site in the whole system.
rr60
Thanks Scott! Save me some legwork. Back to Pirate Radio.
NotATechGuy
NotAMember
I see there is now a Chester site 463.375 (CC 8). What has me tilting my head is that the FCC license is listed as WNRE654 which is licensed for farming with an emissions designation of 11K2F3E. None of that matches anything in this system.
W2SJW
Senior Member
Northwest NJ
I was given that info last night from a trusted source. When working with business-band licenses, you are constantly going to find inconsistencies like this...
NotATechGuy
NotAMember
I left DSD+ open for 12 hours and got zero hits or data bursts. I live about 15 miles away on top of a hill with an antenna up about 40 feet. Maybe it's a very low power output repeater. Can anyone else confirm this frequency?
rr60
The callsign for the Chester frequency is under the name of Alstede Farms which is in Chester.
WNRE654 (ALSTEDE, KURT) FCC Callsign Details
Doubtful its for MICOM/EMS and would explain the farming classification.
Well if that is it, it appears as if that license shows the site elevation at almost 900' MSL w 500 watts ERP yet no digital emissions and no AAT or AGL for the antenna. Odd.
nosoup4u
High Bridge, NJ
I can confirm the Chester site is part of Spectrum. I heard them loud and clear all the way on Route 78 in Warren Twp. and the talkgroup ID was consistent with the Spectrum talkgroup number plan.
W2SJW
Senior Member
Northwest NJ
Thank you! I was getting concerned about the data I was given! That person has been pretty reliable about other Morris County data...
