MicroP25RX
btt
Jew lover
Banned
Wa State
SD Card INIT Failed when I use the zip code search. Do I press anything under SD Card to so it can be read?
You shouldn't need to do anything special for that to work. Try re-seating the card? and try again?
KMG54
Easley S.C.
Oh Todd and you thought the hardware was going to be the hard part.:D
btt
Jew lover
Banned
Wa State
This is where we figure out what else goes into the troubleshooting section of the user manual.
btt
Jew lover
Banned
Wa State
Which SD socket do you have the card in? It needs to be in the socket on the Teensy board and not the socket on the Wio terminal. Could this be the issue?
KMG54
Easley S.C.
I am not being a smart ass. I have studied, but bet I have questions when mine comes on Monday. Can't wait to give a test run. Thank you so much for your work.
  • Like
Reactions: btt
btt
Jew lover
Banned
Wa State
Thank you! I look forward hearing how it does for you.
btt
Jew lover
Banned
Wa State
Story of my life. One of the first to order and will be one of the last to receive.
Looks like they didn't make it by 9pm. Unless they didn't update the tracking. That does happen sometimes. Did you check the mailbox?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
No fault of @btt but as has happened many times with USPS for me my package no longer has a delivery date. All my other mail on Informed Delivery arrived as scheduled.
W0RS
Nixa, MO
I cannot seem to find what size the SD card is in the user manual, I assume it’s a micro size? 128gb, 64gb? I am getting some prepping done before it’s arrival on Tuesday…
KMG54
Easley S.C.
Almost a given mine will be days late or lost here, all packages are, Two day's of calling the post master saying they don't know were it is and telling them it arrived in your post office it arrives the next day
btt
Jew lover
Banned
Wa State
Yes, it is a micro-sd card. Any size will work. You don't need much capacity for the zip code search and csv files. ~50 MB.
KMG54
Easley S.C.
I use the 4 Gig industrial cards from sandisk, they work fine in my scanner and other apps. Not much stored other than text on them so the smaller card would work great.
Stecomp
Slowly working my way through different functions. What are the steps to import RR downloads to get them to populate the zone names? Been awhile since I downloaded any RR and that was to Sentinel or another program. How do you download right to the SD card?
btt
Jew lover
Banned
Wa State
The TG Zones do not have an import function from RR files. The TG Zone names can be edited with the Wio-based keyboard (top-middle button in TG Zone mode) or you can make a backup to the SD card, edit the backup in a text editor, followed by a restore. The filename for the backup is microp25rx_backup.ini
Stecomp
Thanks Todd. Saw this below in manual page 15 and thought that was how you got your displays shown on the video. What more do you get with the RR import if no talk groups are downloaded, just the ID's? Still not clear how to get the DSD .sites from RR to the sd card without a program (Sentinel,PROScan etc.)
IMPORT SITES
Supported talk group files include
• DSD-formatted site files available for download to subscribers on
radioreference.com
btt
Jew lover
Banned
Wa State
Sorry, I thought you meant the TG Zone Names. You are asking how to import the Talk Group Alpha/Description from RR. As a subscriber, you can download the DSD formatted TG files by heading to RR-> DATABASE->FREQUENCY_DATABASE->BROWSE->CLICK_ON_YOUR_STATE->CLICK_ON_YOUR_COUNTY->TRUNKED_SYSTEMS->SYSTEM_NAME->MENU_IN_UPPER_RIGHT_HAND_CORNER->DOWNLOADS. Then download the DSD Formatted Talkgroup data file.
After you download the file, copy it to the SD card. It must have the filename extension lower case of .csv, .dsd, or .groups
Then from the CONFIG mode, select SD CARD->Import Talk Groups. It will automatically locate all talk groups files on the card associated with systems currently known to the receiver.
Stecomp
Exactly what I wanted to know but couldn't find looking for help in RR. Thanks!
Had a few lockups last night while going through functions. Only way to reset was remove from power ( turning off and on and push down reset didn't work). Will have many more questions I'm sure.
Initial impressions of decode of troublesome simulcast system nearby are good. Right up there withe SDSs.
  • Like
Reactions: btt
btt
Jew lover
Banned
Wa State
I know of the potential lock-up issue when changing the DEMOD mode. I will get that fixed. The on/off/reset switch located on the Wio Terminal will only affect the display itself. It will not reset the receiver.
Stecomp
I think that was one of the scenarios when it happened. What exactly do the Demod modes do?
