FLboy850
Seems finally the Ace of Spades VMA-231 AV-8B guys are done. Been a long wind down past year with last
demos,flyovers even working ranges up our way etc. On to the F-35B next.
Wonder if they run most of them out to DM or send some more off to museums etc.
KO4RJX
Benson, NC
Going to miss catching the Harriers flying low in VR1046 which runs just behind my house. Hopefully the F35’s take a run a few times a year on that route.
POTUS to PA tomorrow, then back to WH
3:25 PM THE PRESIDENT departs The White House en route Joint Base Andrews
3:35 PM THE PRESIDENT arrives Joint Base Andrews
3:45 PM THE PRESIDENT departs Joint Base Andrews en route Allegheny County Airport
4:35 PM THE PRESIDENT arrives Allegheny County Airport
4:45 PM THE PRESIDENT departs Allegheny County Airport en route U.S. Steel Corporation - Irvin Works
4:50 PM THE PRESIDENT arrives U.S. Steel Corporation - Irvin Works
6:35 PM THE PRESIDENT departs U.S. Steel Corporation - Irvin Works en route Alleghany County Airport
6:40 PM THE PRESIDENT arrives Allegheny County Airport
6:50 PM THE PRESIDENT departs Allegheny County Airport en route Joint Base Andrews
7:35 PM THE PRESIDENT arrives Joint Base Andrews
7:45 PM THE PRESIDENT departs Joint Base Andrews en route The White House
7:55 PM THE PRESIDENT arrives The White House
TerryPavlick
Wallingford PA Villas NJ
The NAS Wildwood museum where our daughter now works is expecting a AV-8B next week for display. Once here it will be re-assembled and then placed on display.
The Naval Air Station Wildwood (NASW) Aviation Museum, located at Cape May Airport in Lower Township, is preparing to welcome one of the U.S. Marine Corps’ most iconic aircraft: an AV-8B Harrier II+ (Bureau Number 164554).
This battle-hardened jet isn’t just another static display—it’s a veteran of 219 combat missions and 755 combat flight hours across multiple U.S. military campaigns.
The Harrier, known for its unique ability to take off and land vertically like a helicopter, will arrive at NASW by truck on the afternoon of Tuesday, June 4th, depending on transport logistics.
Larry51
Chesapeake, VA
For the Hampton Roads folks. Air wing arrivals into Oceana all morning.
The following frequencies associated with NAS Oceana were active during the return of the squadrons from the Harry S. Truman Carrier Strike Group:
NAS frequencies: 124.825/134.1/310.8/323.05/328.4/352.1/363.1
Squadron frequencies: 311.4/311.95/343.05/343.3/346.45/349.9/353.45
jsoergel
Cincinnati/Dayton, OH
VAQ-144 stopped into Wright-Patterson AFB earlier for fuel as NAVY AB-500 (x2) and NAVY AB-502 (x3). Departed to KLNK as DEVIL 11 and DEVIL 21 flights.
TerryPavlick
AF-1 and spare are holding due to storms A/A 292.800. Say will wait till they pass.
30 seconds behind you Terry LOL.. Heavy storm cell just near Andrews. Should be good in 20 minutes.
There is a Navy GLF5 VV100 holding near Morgantown at 41k.. Smoother up there I bet and prob awaiting ramp freeze.
1955 local seems AF-1 inbound for a try.Storm cell moved East.
