MUTNAV
Previously broadcast RADAR and Frequency outages impacting PHL Area C have been partially resolved with the return of the impact RADAR system. Frequency outages continue with no estimate on a return to service. Additionally, PHL Area C has issued a staffing trigger for 2100z and later.
Based on the continued frequency outages and the upcoming staffing impacts the Ground Stop for EWR and TEB will be expanded to all contiguous U.S. and Canadian departures and extended until 2100z. Once the frequency issues are resolved users should expect a Ground Delay program for EWR and either a Ground Delay program for TEB or an Airspace Flow Program capturing TEB, MMU, CDW, and LDJ.
Haven't really been following this (sounds like important) nwes.... Can anyone expand / explain?
Joel
MUTNAV
Very little info available for airports effected see National Airspace System
Any info (from anyone) about whether this is a computer failure, a hacking event, or something else (staffing.... really)? The Weather seems fine so I'm ruling that out.
Spain and Portugal also had a major power outage earlier, Just trying to see if it's a coincidence or not (maybe someone trying to interfere with as many systems as possible).
Joel
Dutchmil
Amsterdam, the Netherlands
Looks like 4 of the 8 VINYL tankers returned to HNL last night as CABAL 81 to 84 with PINE 31 and 35. ID by ATC as F-35s and I think I actually recognize the voices as VT ANG pilots. (You know you listen to milair to much when ...). The other 4, CABAL 91 to 94 seem to be delayed in Guam. Couldn't find anything on twitter/X to confirm.
Yes, you are right. These are the VT ANG F-35s returning from Kadena airbase in Japan.
The second cell was delayed but should be arriving later today as PINE or SPINE 41flight.
The final FT A-10s that were deployed to Jordan, should be returning home tomorrow from Lajes,
routing via: DOVEY - ACK - HTO - RIFLE - EMJAY - SWL.
Hope this helps,
René.
TerryPavlick
Wallingford PA Villas NJ
1820 EDT
BOS​
Airport Closure
15/12:01 AM EDT—29/11:59 PM EDT
General Edward Lawrence Logan International is closed TO NON SKED TRANSIENT GA ACFT EXC PPR 617-561-2500
Current Airport Config.
Arrival Runway 04R/04L
Departure Runway 04R/04L/09
Arrival Rate 61
Maybe they should ground the GA aircraft so the system does not get saturated
TerryPavlick
I could be mistaken, I read a two-hour Amazon rocket launch window is scheduled starting 7 p.m. EDT Monday, April 28, 2025 from the Cape.
Well clear skies here but if they launch on time (versus way late into their window) - it will not be visible due to sun being above the horizon.
Pushed launch back one minute at 7:01 PM.. Was hoping to see maybe smoky contrail or reflection of shiny Sats.
Will try and take a look anyway :) Lot of clouds down Florida way but crystal clear here.
Yeah nice launch on the tube but nothing seen here. :(
TerryPavlick
Just the trail from the 1st stage and 5 SRBs visible in the South Southwest sky - nothing after it was above the earths atmosphere.
Been a lot better if the sun was already down.
Terry
AirScan
Yes, you are right. These are the VT ANG F-35s returning from Kadena airbase in Japan. The second cell was delayed but should be arriving later today as PINE or SPINE 41flight.
Thanks. Looks like the second cell got airborne but 2 F-35s had to return back to Guam. Not having much luck. Callsign confirmed as PINE on CPDLC.
Tech792
Central NJ
2 UH-60s out of Lakehurst assisting NJ Forest Fire Service with NJ's Jones Road Wildfire. Doing water drops on smoldering, hard to access areas.
Rogue-32 and callsign?? (18-20990 and 19-21047)
Delta-2 NJFFService helicopter (N102NJ)
159.375 fire service tactical air/air, air/ground
I was working underneath them on the parkway but couldn't get any photos.
POTUS Tuesday schedule
2:30 PM THE PRESIDENT departs Joint Base Andrews en route Selfridge Air National Guard Base
3:45 PM THE PRESIDENT arrives Selfridge Air National Guard Base
4:45 PM THE PRESIDENT departs Selfridge Air National Guard Base en route Macomb County Community College Sports Expo Center
5:15 PM THE PRESIDENT arrives Macomb County Community College Sports Expo Center
7:05 PM THE PRESIDENT departs Macomb County Community College Sports Expo Center en route Selfridge Air National Guard Base
7:35 PM THE PRESIDENT arrives Selfridge Air National Guard Base
7:45 PM THE PRESIDENT departs Selfridge Air National Guard Base en route Joint Base Andrews
8:55 PM THE PRESIDENT arrives Joint Base Andrews
9:05 PM THE PRESIDENT departs Joint Base Andrews en route The White House
9:15 PM THE PRESIDENT arrives The White House
Thunderchicken @ SBY.
I like this paint a lot more than the haze gray.
Seems the Mighty Bison of VRM-40 getting used to the East Coast..
BLUE-01 KC-46 #17-46038 headed South East from McConnell for pickup?
Acars has as going to EGUN today. Will be overflying RIFLE and ACK later today.
0937 local Getting weak Boom chatter on Altrav 314.100 coming up the coast occasionally showing as KANZA-25.
Now they are doing trivia on boom freq :)
Fighter is showing miscode ID (20000). Seen F-15E's in Europe use the ID callsign at times.
Maybe F-15E depot return. Moving along fast at 510 knots.
Maybe the next two LN F-15E;s with new defense system EPAWSS after some Tyndall testing.
TerryPavlick
