Mid-Atlantic MilAir 2024
vgames15
Elsmere, Delaware
1725 local BANKER-04 tanker is up in Delaware CAP area on Huntress 260.900
CAP not scheduled till 1845 local.
OT wondering if Barksdale will evac their Buffs as remnants of hurricane expected in Western Louisiana Tuesday.
Fly them to Dover :) though prob to Wright Pat or Minot ND if needed.
Just had visual of a KC46 in the cap boom was down
Quiet CAP fighters.. Little chat A/A 260.900 and on ZDC 363.000.
Headed home and NOBLE-11 flight "uuhh direct the Field"
Finally after long searching they are A/A 270.900 on way back to Shaw? I assume push ZDC Brooke 285.450
Both giving their alpha status on 270.900.. New players? Search here on RR shows freq possible 20th FW from Shaw.
POTUS Travel...
Sunday, July 7, 2024
EDT
9:35 AM THE PRESIDENT departs Wilmington, Delaware en route to Philadelphia, Pennsylvania
9:50 AM THE PRESIDENT arrives to Philadelphia, Pennsylvania Philadelphia International Airport
2:15 PM THE PRESIDENT departs Philadelphia, Pennsylvania en route to Harrisburg, Pennsylvania
2:50 PM THE PRESIDENT arrives to Harrisburg, Pennsylvania Harrisburg International Airport
5:30 PM THE PRESIDENT and THE FIRST LADY depart Harrisburg, Pennsylvania en route to Joint Base Andrews
6:05 PM THE PRESIDENT and THE FIRST LADY arrive to Joint Base Andrews
6:15 PM THE PRESIDENT and THE FIRST LADY depart Joint Base Andrews en route to the White House
6:25 PM THE PRESIDENT and THE FIRST LADY arrive to the White House
TerryPavlick
Wallingford PA Villas NJ
AF-1 inbound KILG runway 19 with female pilot :)
Was a CG C6606 grid search down near Terry's Villas place in South Jersey.Seems on its way back.
Early afternoon a pleasure boat about 2 miles northwest of my location reported finding a purple kayak that was floating upside down in the Delaware Bay about 1/2 mile or less off shore (basically in the middle of the tracks shown SW to NE). USCG Station Cape May discussed the situation and then dispatched a USCG Small Boat CG29286 to the scene to retrieve the kayak and do a search. USCG 6606 was called in to assist with an air search and NJ State Marine Police boat assisted as well. No one was located after about a four hour search. Marine Channel 22 was used by Station Cape May to communicate with the pleasure boat and between the pleasure boat and CG29286. CG409 (412.975 P25 mode NAC 293) was used to communicate between CG29286 and Station Cape May. The station and the small boat were in the clear and 6606 was encrypted. CG29286 and the NJ State Marine Police boat coordinated on Marine Channel 9 (156.450 FM).
6606 was then redirected to search off the NJ coast based on a distress call received on Marine Channel 16 (156.800 FM). That is the direct track you see from the shore line across the county to the ocean side (up the coast and then back down).
The 6606 used 345.000 AM mode to communicate with other USCG air assets when doing the ocean search.
frank3si
New Castle DE
POTUS Travel...
EDT
Interesting, as KYW Newsradio in Philadelphia last night was saying his Sunday appearance was cancelled due to a union picket line he did not want to cross. Unless they came up with a substitute appearance?
Philly Inquirer this morning says Potus to a Black Church in Philly Sunday with statement afterwards then
off to Harrisburg. I haven't seen a TFR notam for Harrisburg posted yet but am sure will be posted later.
One of the NOBLE's gave tail # to tanker 00-0226 which comes back to F-16CM-50 from 79th FS Shaw.
Nice newer F-16's :)
NOBLE tells tanker Banker-11 Thanks and see ya tomorrow..
Banker-11 recovering at Dover on CP 349.400 and apch 132.425.
apex31
Am I right in saying that it seems a good amount of CAP tankers in the past month or so have been working out of Dover? I wonder if there’s any specific reason Pease seems to be on the quieter side recently.
1040L - EIDER15 (C-17 03-3122) on final into KPHL.
tazz
Wellston, Ohio 45692
1210- Couple of Langley T-38s (BT 01 (unid) & RR01 (Raster) off Langley heading northwest. A2A is 238.825. RR 01 is about 100 miles behind BT 01.
Currently over Southern Ohio. Still using 238.825 MHz for air to air.
Working ATC on the following freqs .....
Indianapolis Center ARTCC Sector 77 University on 353.525 MHz
Indianapolis Center ARTCC Sector 78 Springfield on 282.375 MHz
Indianapolis Center ARTCC Sector 88 Dayton on 317.625 MHz
I think they are en route to do a fly-over somewhere around the Chicago area. They advised ATC they were going direct Ft Wayne for the GOSHEN NINE arrival into Chicago.
