Midland repeater
Looks like it's along the lines of the Retrivis repeater. Low power, cheap flat pack duplexer.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
They’ve discussed this on another forum. It appears that the Midland is the Retivis relabeled.
Project25_MASTR
TX-COMU
Texas
Midland had relabeled several manufacturers repeaters over the last decade or so and offered them in various services (LMR, GMRS, etc). Doesn't surprise me that they are trying to cash in on GMRS.
techman210
San Bernardino County
Look at their “Base Tech” commercial repeaters that they had over 10 years ago. They were made by “Oki” an old Japanese manufacturer of cellphones back in the ‘80s. They had many customers including the California Highway Patrol.
Unfortunately the Oki factory was taken out by the tsunami in 2011.
bill4long
Indianapolis
Retevis. It's got DB9 pin out for external interfacing. It's perfect if you want to get a backyard repeater up and linked to one of the GMRS networks taking over GMRS. Retevis is pushing this theme. I might buy one myself just for funzies.
Delivers1234
Modesto, CA
Are they the same specs but with a midland label?
It looks like you can repeat all the gmrs channels at the same time. Is this correct?
It has a channel selector, so you can program in up to 16 channels. Looks like it ships with all 8 GMRS pairs loaded in as wide deviation, and then all 8 loaded in as narrow deviation. You'd select which channel you want to use.
The small mobile duplexers are wide enough that they wouldn't necessarily need tuning over the entire GMRS band to work (but would probably benefit from tuning to the exact pair you plan on using).
