MILAIR Database
mancow
N.E. Kansas
Oh I forgot about you clearing out those certain freqs. That does help a lot.
rbm
Upstate New York
I attempted to cut & paste the entire list into my BCT15X, using ARC-XT, but the software crashed. Looks like I might have to chop it up into smaller segments.
Maybe I can help with that.
I created a number of files in Uniden UASD format. (That's how my data is maintained)
Attached is a zipfile with those System files.
You can import those files, individually or as a group, into FreeSCAN directly via ... File -> Import -> From UASD
Listed below are the names of the files. (It's easier to read in the attached .txt file ;)
The first two digits are the 'System Quick Key' for that file.
Next is the frequency range in that file.
I have more than 40 Uniden scanners so ....................
I tried to make everything work with all versions of BCT15*, BCD396*, and BCD996*.
Therefore I limited the frequencies in each system to 200. That will work for all of those models.
You'll see a few that share the same System Quick Key because that frequency range had more than 200 listings. (i.e. 23 & 23a, 24 & 24a etc.)
I also included a FreeSCAN (_MilAir_Files-22-37.996) file that includes all of those files with those SQK's assigned.
Rich
22 225-229 MHz MilAir
23 230-235 MHz MilAir
23a 236-241 MHz MilAir
24 242-248 MHz MilAir
24a 249-253 MHz MilAir
25 254-257 MHz MilAir
25a 258-264 MHz MilAir
26 265-269 MHz MilAir
27 270-275 MHz MilAir
27a 276-281 MHz MilAir
28 282-288 MHz MilAir
28a 289-293 MHz MilAir
29 294-305 MHz MilAir
30 306-310 MHz MilAir
31 311-318 MHz MilAir
31a 319-328 MHz MilAir
33 335-343 MHz MilAir
34 346-353 MHz MilAir
35 354-362 MHz MilAir
36 363-372 MHz MilAir
37 373-378 MHz MilAir
37a 379-380 MHz MilAir
  • MilAir_Files_10-07-2014.ZIP
  • FileList.txt
BMT
Thanks RBM!!
You probably helped a lot of guys.
BMT
iMONITOR
Silent Key
S.E. Michigan
Thanks RBM!!
BMT
Both of you have been a great help with your contributions! RR is very fortunate to have members like yourselves. This is how forums are supposed to work!
rbm
Upstate New York
Thanks BMT and iMONITOR.
If we all had to do everything on our own, we wouldn't have nearly as much fun.
Rich
kg4ojj
Crisp County, GA, USA
Here is the BCDx36HP version. I separated the 3,813 frequencies into 38 'departments', where each department holds 100 channels (labeled Channel 001 to 100).
Simple enough, right? Feel free to add your Quick Keys to each 'Department', etc.
Save file to a known location and change the ".txt" to ".hpe"
Import file via Sentinel software (File > Import from hpe file).
  • 2014 FALL BMT MILAIR.txt
joeuser
The Wretched
North Central Kansas
You sir, are my hero! I was wondering how I was going to work with this...
mancow
N.E. Kansas
Very nice. Thank you for doing this.
kg4ojj
Happy to help. YMMV, but it'll take a long time to scan through those frequencies on one scanner. Best to split that bunch into little bunches....of scanners.
Sent from my SCH-I545 using Tapatalk
joeuser
The Wretched
That was my plan 4 - 1000 channel units...
joeuser
The Wretched
Now that I think about it, I might run these on the 396T... That way I can search the 200-500 range with these other rigs...
kg4ojj
Give some love to the 138-144 range, too. My neighborhood A10s love VHF AM @ 143.150
Haley
I will second that, the amount of information in this thread is incredible! Mike
rbm
Upstate New York
For anyone interested in the 138-144 MHz (AM) range, I created a Uniden programming file for BCT15, BCD396, BCD996, etc. scanners.
(240 frequencies)
Each MHz is a 'Group' within that system file.
Since the BCD396T had a 200 frequency per system limit, I also split the original file into two files of 120 frequencies each for that scanner.
The first two digits in the file name are the 'System Quick Key. (19 in this case).
You can either use the Uniden programming software or 'import' them into FreeSCAN.
Rich
19 MilAir VHF 138-144.USD
or
19a MilAir VHF 138-140.USD
19b MilAir VHF 141-144.USD
  • MilAir_VHF_138-144.ZIP
joeuser
The Wretched
(240 frequencies)
Rich
or
I throw my sincere appreciation upon you kind sir!
BMT
Thanks,
That's much better than some of the things I've had thrown at me. ;)
Rich
I had a joker tell me to sell all my equipment and delete all my files.
He said" you don't understand how to monitor MILAIR". ;-))
BMT
rbm
Upstate New York
Thanks,
BMT
Heck, my wife tells me that every day. ;) Or more!
But then, she's constantly telling me about things she hears on the scanner in the kitchen.
She likes listening, but doesn't like admitting it.
Rich
