Milair traffic heard today
autovon
Ø
I think they were in the Crypt MOA today. Heard some chatter on the scanner before leaving the house this afternoon.
nodak1crdet3
Detroit, MI
Logs from 11-07-11,12:17 pm to 08:54 pm.
348.300 unknown VOLK area use with CYCLONE-21 at 02:pM
238.200 ACC/TAC A2A with unknown in the VOLK area 04:56 PM
Note other call signs used during practice sortie was MAD HOG and BROCHURE.
other freqs used
346.525 VOLK / PHOENIX
rick
Hi Rick,
348.300 WI F-16's new TAC A/A freq.
238.200 WI F-16's new TAC A/A freq.
jimlawrence
297.3 - sounds like refueling coordination. Anyone got any idea which AR track this frequency is associated with?
autovon
Ø
406 Low and High have been around a while. They're more or less along the IA/MO and NE/KS border.
jimlawrence
Thanks! Didn't see it in my documents. Do you know what the secondary/backup is?
N9JCQ
Lake Barrington, IL
Autovon and all, The Carma doc is a decent baseline in my opinion but you'll note the date of the document. A lot has changed since then.
jimlawrence
Active Logs today:
354.1 - Chicago Center
372.0 - Minneapolis Center
319.2 - Chicago Center S. of Iowa City
363.1 - Minneapolis Center - NW Iowa
250.85 - IA ANG
238.9 - Air refueling
splash1
Eastern Iowa
Had a little time this am for monitoring .
10:12 am (260.200 REFUEL SEC 318) air to air chit- chat about being on wrong frequency.
10:32 am (391.000 BRAVO 2x primary) Refueling // updating eta and changing callsigns from (sounded like TREND) to DEMON 01 thru 06.
rick
ka0pmd
Chicago, Illinois
Voice comms heard in Winterset, IA today...
I'm listening on a PSR-800. It's in the other room, so I haven't had a chance to look at frequencies, but will continue listening.
HAWKEYE ONE TWO is dropping GBU 12s on a treeline not far from here, "Dropping on the green smoke, and I do not see muzzle flashes; we will drop sensors on the site."
"Burma...good hits...no need for another reattack."
"Hawkeye One-Two has captured your location; sensors on."
"Danger close for a GBU-38 airburst."
"Cyclone push eleven, 288.3." "Checking in, Level 10,000."
"Okay, Hawkeye, that's all we got; we gotta go home for land time."
"Back to initial; push 3."
MCWKen
Clinton, IA
A few notes from this weekend. Mostly PAT flights of BE20's out and about over the weekend, one flight decided to take a few touch and go's at MCW.
While I was out with the ADS-B laptop this weekend, noted coverage in the area of both VHF and Uniform frequencies, especially originating at MCW. I know many databases show Uniform frequencies that are not used here so here is the current usage. High altitude is 323.0250, coverage with a mobile antenna is about 30nm surrounding MCW. Low altitude is 257.6750, with a useful coverage of a bit less than the high alt frequency, again using a mobile ¼ wave antenna. With the MCW ATC antennas being at 1250 feet, the VHF range is barely 20 miles, even on top of ridges.
MCWKen
Clinton, IA
Crypt South, Central, North hot at 1830 hours. Hawkeye 11 flight of 2, Cyclone 21 flight of four in the airspace. Talking to Coffin Corners 311.300mhz.
MCWKen
Clinton, IA
Friday 04/26
Crypt North active with Texas 61, 51, 41, and 31 (F-16's from 111th FS/147th FW TX ANG Ellington ANGB, TX) fueling with Upset 51 and Upset 52 (KC-135). Lot of aircraft for such a small MOA.
Tactical is 321.200
autovon
Ø
Also heard today: Mentions of CRYPT and callsign CYCLONE.
Don't know if you knew it or not, but Crypt is the MOA in NW Iowa and Cyclone is one of the F-16 callsigns out of Des Moines. Take advantage of the F-16 traffic while you can, the jets are leaving Des Moines fairly soon. :(
