Mini antenna from Amazon?
nd5y
Wichita Falls, TX
It's probably a copy of PA0RDT Mini Whip Antenna design. Do a search for that. There are several articles and web sites about it.
jonwienke
More Info Coming Soon!
VA
Something that small is going to be crap below 30mhz. Physics is unforgiving.
Gadgeteer2000
Paris, France
Thank you! Will do. Amazing - so this is really an antenna! I am learning new things every day.
Now time to read up.
Thank you again!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It looks like it might be a Chinese ripoff ...
it can be made to work - after all, the well known University of Twente SDR uses a PA0RDT antenna. However they do take some work to tame them. See this article from SWLing.com
Mike
merlin
DN32su
Yes, I have one of those. They have to be installed per directions but in that, they do work well.
Indoors you might be a bit disappointed.
I have an 18 foot length of copper wire strung out the window, goes to an antenna tuner then to a preselector.
Works about the same as the mini whip just above the roof line.
Another hint is use good low loss coax coax. Don't skimp there.
This is the mini whip I got,,the kit, but they have assembled also. Not the cheap Chinese knock off.
