MInitor V Programming Question
bhartley
Looking to procure a Minitor V for personnel use but before I do I wanted to make sure that these frequencies could be programmed in. I'm looking at the VHF band split which to my knowledge is 151-158.9975MHz.
The two freq's I wanted programmed in would be 154.8450 and 159.1200. I realize the 2nd freq is out of band but not by much (don't know if there is out of band "limits").
So the question is this...Can these freq's be programmed into a Minitor V and if so is there a special way to get the software to write.
NCFire11
It will work. But the PPS throws this at you when you try:
The PPS will still write that frequency to the pager.
