Minitor V stored voice
codymw623
Ebensburg PA
Hi,
I have a Minitor V Stored voice pager. I was wondering is there a way to disable the stored voice function. I really do not have a need for it and it gets annoying when the tones are set off and all you hear is squelch till someone decides to talk.
Thanks,
Cody
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hi,
Thanks,
Cody
Under the Model Options tab, change the Reset Function to Revert. The pager will then immediately revert to monitor mode after receiving a select call.
The Help file says there is an OFF setting for SV in addition to the record time choices under Reset Function, but I don't find it in the PPS version that I have which is the latest. So you can't really disable SV, but you can fix that annoying squelch burst. The burst is there under the Revert N option to keep the SV recorder going if the dispatcher drops carrier between the tones and the voice message. That happens a lot and not necessarily because of dispatcher error or laxity. It's very common for a carrier drop if there are stacked pages on more than one channel.
