ProScan: Missing audio files.
VE5JL
Saskatchewan VE5 Land
When I delete recording rows on my Proscan, does it also delete the audio and if so can I get it back? It's not in the recycle bin?
Thank you 73
Joe
VE5JL
Thank you, I however didn't delete the ones in the main folder. I'm using 2 scanners and I thought I was deleting the History Logging on the 2nd scanner and not the audio files.
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Deleting items from your history log won't affect your recorded files. Only if you delete items from your recorder log will the associated mp3 files be deleted
VE5JL
Thank you for this. I think I inadvertently did this as I'm using 2 scanners and I didn't want the log to show up on my second scanner. I looked to see if the delete files were in the recycle bin but they are not. :(
VE5JL
When I boot up a second session of Proscan, it opens up the same files. I'm only recording from one scanner and not the second one.
How do I separate the logging of the 2 scanners?
Thanks for the question.
buddrousa
Here are the scanners
full
