_DeS_
I was wondering if someone might be able to help with my problem. I will describe this in as much detail as I can.
Firstly my problem. As the title suggests I miss the audio on my SDS100 that I pick up on either other scanners or radios for the specific system.
This may be in the form of the first transmission i.e Dispatch hailing a resource not being heard while the SDS100 stops on the transmission and I only hear the resource responding i.e. Go Ahead dispatch.
My set up is a SDS100, updated to recent firmware with a Remtronix antenna for the specific band I'm monitoring.
I'm monitoring the Maritime Public Safety Radio Network (MPSRN) in Nova Scotia, Canada.
I have my scanner set up to monitor only the sites in the network that would be geographically probable for me to receive as I travel around my area. These are all the sites listed as being located in Cape Breton in the network site list. While I'am stationary I turn off (ignore) the sites that would be farthest away from me and leave the closest sites enabled as well as a handful of VHF frequencies.
Geographically site strength for me switches between Site 64 Glace Bay & Site 63 Coxheath. As the crow flies, Site 64 is closer to me. If I use my TMR radio and force a site affiliation 9/10 it will affiliate with Glace Bay strongly. Now I know that a Radio designed for the network is different than a scanner but I mention just to give as much info as possible.
I have this problem if I scan both sites or turn one or the other off. I do not live in or around a "noisy" area and here is the current signal information for the sites mentioned.
My TMR Radio has affiliated with Site 63 with a RSSI 58.
SDS100 on Site 64 RSSI -80dbm steady with 0 D-errors strength bars remain constant and "DATA" is displayed constantly while on hold as well as all the sysinfo I want dispalayed stays in view.
SDS100 on Site 63 RSSI -90dbm fluctuates to -95, D-errors 20 ( would be an approximate average ) this fluctuates from 0 to as high as 90. I notice on this site as well that the signal strenght bars bounce around alot and the "DATA" is lost.
I think that about covers it...So my thinking is, now correct me if I'm wrong, I would be able to potentially hear more agencies if I scanned both sites, or is that completely wrong ?
So If anyone can point me in the direction of where to start looking at settings or what not I would greatly appreciate it. Just to give a example that just occurred, I have the SDS on hold on site 64 which is Glace Bay and seems to be the most stable and strong site, I could hear a unit in the field hailing Dispatch, I hear nothing, then I hear that same unit continue with their information, THEN I hear dispatch acknowledge that transmission. Bizarre.
Thanks for any suggestions !
