SailorDan
TL;DR: Is there a performance benefit to using a separate 1/4 wave 2m and a 1/2 wave 70cm antennas and combining inputs with a duplexer as compared to using a single dual band antenna? What would be optimal positioning (48" x 82" roof)? What about adding a scanner antenna?
I'm finally getting around to installing my mobile (FTM-400XDR) in a Jeep Cherokee. I'm planing on drilling the roof for permanent mounts because of expected improved performance compared to a hood/fender mount. I'm considering using 2 dedicated band specific antennas instead of a single dual band because of decreased height (the dual banders I've seen are coming in 30"ish)- might I see a performance increase as well?
Mounting location - If one antenna, I'd put it in the middle of roof. If two antennas, I'd mount midline dividing roof into thirds (about 2ft between each)
--- What about adding a scanner antenna? Should I place it on the hood (about 1.5' vertical and 3.5' horizontal separation from nearest transmitting antenna) or could I place it midline/front of the roof and the transmitting antennas at the rear of the roof on left/right side?
From my research, placing the scanner antenna on hood would be the safest for the scanner, but I loose a 360 ground plane.
How would you configure these 2-3 antennas? Unfortunately a dual bander on the roof won't fit my parking garage - not sure it would be worth the inconvenience of lowering each time - and eventually forgetting.
All - I just stumbled across a post by CopperWhopper67, where mmckenna provides some great input and answers many of my questions.
I'm always open to suggestions, but I think I have a way forward.
The Jeep is gutted on the inside so I would like to install mounts now with an eye towards future flexibility - swap antennas out as use case / radios change.
I am still interested in knowing if there is a compromise in performance of a dual band antenna compared to a band specific antenna.
